Thread: Emissions - 1.9CDTi
    Regular Member HappyHarry's Avatar
    Wolstanton, Newcastle-under-lyme.
    Default Emissions - 1.9CDTi
    Car flew it's MOT today...86k, Straight pass, no advisories on wearing upper lower wassinks or whatever. I note, however the emmisions CO2 opacity score was 148... and the pass mark is 150 ot lower. Is this just cheapo fuel or should I start chewing my fingernails about EGR valves and the like? TIA.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Do you have any black smoke when you floor it as it's basically close to failing te smoke test there must be noticeable smoke when you boot it
    Not really...I gave it a good hoof up to 4k a couple of times on the way to the test and had a look behind, but didn't notice much (mind you, it was a damp, dark morning so visibility were not exactly great....
    Oct 2007
    Ripon
    What would need to be done to reduce the 'smoke' figure?
    kings lynn, norfolk
    A good service air filter change, clean boost sensor, clean egr valve, clean maf, give it a good high speed thrash with redex diesel cleaner or millers treatment and shell v power diesel should sort things out a bit
    May 2007
    Grays Essex
    having the engine at operating temp when presented at mot is the most important thing (ps i am a mot tester)
    Huddersfield
    I know you red lined it en route but do you just do that yearly? It might be that you've loosened a few soot deposits.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by robdd1 View Post
    dont look back in the mirror & take your car elsewhere for its mot!, .
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. egr/emissions
    By squiggy4 in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. Emissions
    By sb1uk in forum Engine & Drivetrain
    Last Post: 10th April 2009, 12:41
  4. Emissions
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 19:36
  5. The 3.2, the MOT, the emissions
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 20:26
vectra c 1.9 cdti emissions
vectra c 1.9 cdti emision
lowering emussions vectra cdti
