Thread: corroded front and rear brake discs.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default corroded front and rear brake discs.
    hi,would corroded front and rear brake discs cause the car to feel like the wheels are unbalanced at motorway speed?kwik fit just checked car over and sais discs are corroded and you can physically see but the rear tyres did not get done just the front.cheers
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    Corroded discs alone wouldn't, but if they are warped in any way, then yes. Are you getting a pulsing through the brake pedal when you apply the brakes?
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    no not at all.do you think it would be worth getting rear wheels balanced?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 74000
    Is the vibration through the steering wheel or the floor/seats? If its through the floor/seats that generally means the rear wheels need balanced.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    yeah its through the floor/seats mate.cheers will get rear wheels done and see if that solves it.
    Corroded or end of life discs normally make excessive noise during light braking
    If there is no noise, there is no issue with them
    The rears are usually worse as they are easier to hear
  1. Front brake discs
    By keefy*2010 in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2012, 22:39
  2. rear discs - one corroded, one isnt??
    By m111kan in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2011, 18:27
  3. Corroded front brake pipes
    By sheepish in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2010, 14:04
  4. Front brake discs
    By baluachrach in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2010, 22:10
  5. new front brake discs?
    By kev bux in forum Handling & Braking
    Last Post: 19th October 2007, 19:33
