Thread: Tyre load ratings.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Tyre load ratings.
    Just seeing what peoples thoughts are on tyre ratings.
    As i'm now having problems with the tyre fouling the inside arch i've been looking at tyres when i need to replace them.
    Size at the moment is 235/35/19 with a load rating of 91 but was thinking of going for 225/35/19 but the load rating is 88.
    After some really good comments i will be going for some Neuton NT5000 and both these sizes are available at a very reasonable price.
    Will a load rating of 88 be too low on a GSi.
    Thanks people.
    Regular Member Grimy's Avatar
    I would say so yes, way too low. You should by on extra load tyres at that size and with the big heavy steel v6. I looked into the same thing when choosing mine a while back and from memory I think you should have a min of 91 possibly higher.
    Looking back, Vauxhall fitted 95 as standard on the gsi so i read.
    Regular Member Jezzy's Avatar
    S.E
    88 allows for 560 kg per tyre, or 2240 kg for the car. You need to know the max gross weight of the car (i.e. including passengers and luggage) and then add on 25% to account for extra loads put on one or two tyres during braking or cornering. If that figure exceeds 2240 kg then 88 isn't high enough.
    Nov 2010
    Sheffield
    To be on the safe side I would never fit a tyre that had a lower load (or speed) rating than what was originally fitted when new.
    Nov 2010
    Sheffield
    To be on the safe side I would never fit a tyre that had a lower load (or speed) rating than what was originally fitted when new. No niggling doubts that way.
    Regular Member wardy's Avatar
    Chichester
    235/35 is the correct size for 19s on the vec. So why are they catching? Have you lowered the car (too much)? Don't think the tyre size is the problem.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by wardy View Post
    Yeah, lowered 45mm (or 30mm as GSi) on PI springs. Only seems to be rubbing on the nearside.
    Got some 5mm spacers to see if that helps.
  1. Tyre load rating
    By Threepiers in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 21:18
  2. Tyre Load Rating?
    By Grimy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 22:17
  3. Tyre load index
    By Roadhog in forum Handling & Braking
    Last Post: 28th April 2009, 09:53
  4. tyre load calculator
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2009, 08:20
  5. Tyre load ratings for Vectra 3.0 CDTi
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2008, 10:22
