Thread: Alternator Diagnostics
    Reading
    Default Alternator Diagnostics
    Hi
    I have an alternator fault and have taken a few readings and wanted to check whether my diagnosis was sound.
    With the engine off, reading 12.10 VDC across battery
    With engine running, VDC drops steadily instead of increasing, indicating alternator not charging.
    Now, if I take an AC measurement across the battery, I get 18VAC. Is this an indicator that it is the diode/rectifier that has failed, and if so, is this part servicable ?
    TIA
    Steve
    Regular Member signumturbo04's Avatar
    SCOTLAND
    dunno about the rectifier but i chaanged the diode pack in my 2.0t alternator for less than £2
    Reading
    sounds like the kinda thing I'm looking for. Where did you get the replacement diodes from ?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Quote Originally Posted by steveh2009 View Post
    What should the VAC value be if it was a good battery?
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    It sounds like Diode/Rectifier to me as it sounds as though the AC from the Stators is going straight through. You should not be getting 18VAC.
    Get the make/model number of your alternator and check out ebay for a new pack.
    Or see if you can get an exchange alternator from your local motor factors.
    Regular Member LADmachining's Avatar
    Hampshire
    You will normally get a little AC ripple from a working alternator - usually only a matter of a few mV, no way should you be getting volts AC across a battery.
    Looking at this ripple voltage on an oscilloscope is a good way of diagnosing faults with the charging system, once you know what to look for.
  1. Diagnostics
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 03:08
  2. Diagnostics
    By neill in forum North West (RO - bonehead, ARO Woody
    Last Post: 10th April 2012, 19:55
  3. been to vx for diagnostics :(
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th March 2011, 20:33
  4. VW Diagnostics
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 29th April 2009, 09:33
