Results 1 to 3 of 3
Thread: Handbrake Recall......
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Handbrake Recall......
    This isn't a technical thread so posting it in the "car chat" area...
    I've owned my 2002 Vec C for nearly two years now, and after 8 years of it's life Vauxhall have finally caught up with it and posted me a letter about the hand brake!
    I'm sure lots of you have had the letter previously, but it's claiming if you press the button in when applying the hand brake (as I've always done) it can manipulate the mechanism causing it to release partially.
    I'll probably will get this work done, although it will put me out as my nearest dealer is approx 6miles away and I work at least 35miles away, so can't do without it.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Well worth getting it done. Involves fitting of a stronger spring, as the existing one has been known to cause the mechanism to release itself. The brake will feel firmer and more 'solid' when applied after the fix.
    Keeping the car in gear when parked is always a good idea.
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    I took mine in the other day and it took all of 5 minutes to do so you could phone up prior to getting it done to make sure they have the part and ask them to do it there and then while you wait.
  1. Handbrake Recall for my 06 Vec
    By Envy in forum RECALLS
    Last Post: 29th January 2011, 11:18
  2. handbrake recall
    By veccyjay in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2009, 14:15
  3. handbrake recall
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2008, 21:27
  4. Handbrake - Recall
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2008, 19:53
  5. Handbrake recall.
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2008, 00:35
