Results 1 to 10 of 16
Thread: Heater switch problem (Fan)
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Default Heater switch problem (Fan)
    Fan only working on number 4, think I have seen somewhere that this is a common problem, can anyone advise on this please????
    cambs
    yep common problem
    you need a new heater resistor
    have a look here
    http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    Regular Member Steve01's Avatar
    Aberdeenshire
    Most probably the resistor in the blower! Blocked drain in the scuttle panel,water overflows and goes into the blower. Pollen filter be soaked too! Do you get a smell sometimes through the heater? This is a tell tale sign mine used to do it after using the air con!
    Sep 2010
    Telford
    Thanks lads
    had the same problem when i got the car, had it sorted and now seems to have gone again,
    were is the drain that could be blocked, washed it yeserday including under bonet, no smell in the car
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The scuttle drain that gets blocked is under a lift section of the plastic scuttle - bonnet up, plastic goes along base of windscreen, pull off passenger end of rubber strip and lift approx 12" section of the plastic panel with 'venting' above it.
    Below that you will find the cabin air intake with pollen filter in front of it and scuttle drain below that toward the middle of the car.
    If clearing the drain, replacing/drying out the pollen filter and replacing the thermal resistor doesn't cure it, you might want to check the blower relays in the passenger footwell area.
    Sep 2010
    Telford
    Quote Originally Posted by Handyandy-UK View Post
    Thanks I'll have a look tomorrow,
    when I washed down by the rad I knocked a switch off in front of the rad, pushed it back on could this have anything to do with the problem?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Badger59 View Post
    knocked off a switch ??
    possibly the outside temp sensor ?
    Sep 2010
    Telford
    its a switch opposite the Rad on the inside of the bumper, cleaning round with a cloth and court the switch pushed it back, just wondered,
    Should be covered on the warrantee, just thought I could do it myself to save messing about, is it an easy fix if itís the resistor?
    Aberdeenshire
    Yes its easy enough mate just a bit fiddly! Gotta take out the glove box and its behind there! Resistor is about 10 - 15 quid iirc! Apparently you can repair it but I would just replace it tbh
    Sep 2010
    Telford
    Quote Originally Posted by Steve01 View Post
    think thatís what the garage must have done when I got the car, if they replaced it it hasnít lasted long, Iíll contact the warrantee company, if they cost about £15 may as well let them pay, thanks again
  1. Please help, heater problem
    By foxyland in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2012, 08:47
  2. My heater postions take forever to switch over
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2008, 21:20
  3. Heater Control Switch Panel
    By leeds vectra in forum Parts for sale
    Last Post: 22nd January 2008, 03:18
  4. Heater Switch Problem
    By precesh in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2008, 10:43
