Thread: Rubbing noise on full lock.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Rubbing noise on full lock.
    Finished the suspension off yesterday but have noticed that when on full lock to go right theres a rubbing noise.
    Cars got 19" snowies and PI 45mm lowering springs with standard shockers.
    Doesn't seem to do it on full lock left and didn't seem to do it with the coilovers on.
    Checked to see if the spring seat might have been the cause but looks like its nowhere near the wheel or tyre.
    Any thoughts people
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Right, had a look at work tonight and it seems the wheel and tyre are rubbing on the inner arch on full lock.
    Has anyone else had a problem like this as speaking to Vauxhall the car will fail its MOT because of it. Just seems silly to have Vectra wheels on a Vectra and for them to catch on bodywork.
    Was thinking to cure it to put some spacers on (say 6mm).
    Glasgow
    It would'nt rub if you did'nt have aftermarket springs on it there designed to run on springs that come fitted to the car. Not much point talking to vauxhall as you have modified it.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by byebyeitsagsi View Post
    Only speaking to Vauxhall due to having a free MOT with them.
    There is alot of people on here that have 19" wheels or bigger and have lowered their cars but they don't seem to have any problems.
    Glasgow
    Ah right got you now. A 45mm drop and running 19's will be tight. Might be worth checking the wheel arch liners are secure and tightly fitted.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    I think some spacers are required once i get paid.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Just drop the tyre thickness.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by Vectra_C_Chris View Post
    Can't do that, already on 35 profile. When i got to buy new tyres i think i'll see if i can get 225's instead of 235's.
    In the meantime i've just went and bought some 5mm spacers from Halfords as it does only seem to rub on extreme lock.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    UPDATE:
    Fitted the 5mm spacers tonight and they seemed to have done the trick.
    Once christmas and new year is out the way i might go and buy some 6mm ones to replace the 5mm ones on the front (to be on the safe side) and bung the 5's on the back.
  1. Knocking noise when steering full lock and driving
    By ayrshirekillie in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2013, 15:55
  2. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  3. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  4. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
  5. Rubbing noise
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 23:56
