Thread: quick question
    Regular Member scottyd's Avatar
    paisley
    Default quick question
    hi guys just a quick question, my rear window is always covered in ice on the inside and always seems covered in condensation it goes away ok when csar is running, any ideas how to cure it? car need a thermostat but it does get warmish when running, thanks in advance
    Jul 2009
    The Rift, Cardiff
    Take out the boot floor and the spare wheel and check for water in the wheel well and make sure the drains are clear.
    There are a couple of places where water could be getting in such as the rubber seals around the boot opening or the lights.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Use the aircon to help remove residual moisture too.
    East Midlands
    I have the same mate,generally the cars are prone to this and theres not much you can do apart from running the air con continually,i have no leaks and it still does it.
    paisley
    just checked boot and totaly dry oh well looks like i'll have to live with it!!! its still under warranty might ask then to look at it!!
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Only one problem with the 'running the aircon' plan of attack..... the ice tends to form when the temp is below about +2c.... the aircon doesn't work below +5c. Plenty of ventilation certainly helps though.
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
