Thread: Problems with washer jets
    Dec 2010
    Default Problems with washer jets
    Hi everyone
    New to the forum.
    Just took delivery of a 58 plate Vectra SRi and after receiving it noticed the washers weren't working. Due to the cold weather I checked to see if the fluid was frozen and it wasn't, but didn't look as if it has screen wash in it so I decided to syphon it off and put in extra strength screen wash. Have put a pin in each of the washer jets (front and back) and still they don't work. The motor is running but not a dribble comes out front or rear - any ideas?
    Wales, UK
    The jets do freeze pretty good, so this may be a possibility ? Have you tried taking the pipes off the jets to see if the water comes through ? There could be a blockage further into the jet...
    Tip, poor boiling water over the pipe, you wont get it off otherwise
    Hope this helps.
    Jul 2009
    The Rift, Cardiff
    The filter might be blocked or slimed up.
    13 Post(s)
    Quote Originally Posted by ChrisBilly View Post
    See the how2 I did for cleaning the rubber filter.
    East Midlands
    Yep clogged filter,you need to remove the left hand inner wheel arch to gain access to washer pump and then de gunge and clean.
    13 Post(s)
    Quote Originally Posted by macdad View Post
    you need to remove the left hand inner wheel arch.
    No need to remove, just undo a couple of torx screws and peel it back slightly - as per the info in the how2.
  1. washer jets
    Last Post: 11th November 2011, 20:18
  2. Washer Jets!
    By Netstar in forum Bodywork & Interior
    Last Post: 3rd February 2011, 16:00
  3. Washer jets.
    By Rennie in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2010, 18:22
  4. washer jets
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 19:32
  5. AFL washer Jets
    By CorsaVan in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 19:18
