Thread: Misted windows - found the problem!
    jilava
    Default Misted windows - found the problem!
    So as temperatures start going below -2 degrees C now around where I live, the AC compressor stops working and there's no dehumidifying of the interior air. The windows on my car get so misted up, the other day I had to keep the demist ON all the time while going to work and even so the windscreen remained misted up on the sides.
    So I have just checked the recirculaton flap behind the polen filter and it was jammed closed. I forced it open by hand and tryed it again, sometimes it works, sometimes it remains stuck closed. So I just forced it open and deselected the air quality sensor so the flap will allways remain open.
    It probabily remains stuck because of a broken tooth on a gear wheel like The-wizard has found on this thread.
    http://www.vectra-c.com/forum/showthread.php?t=105649
    I also had the wierd clicking under the dash but it went away a few months ago and didn't think about it.
    Also this is the full thread on the air recirculation servo replacement by The-wizard: http://www.vectra-c.com/forum/showpo...79&postcount=1
    HTH
    Cheers!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yeah I have the condensation problem too and my recirculation flap is bust - judging by the noise the stupid motor makes.
    Gazza4
    jilava
    Just got to work now and no sign of condensation on any window! . But I could smell the fumes from other cars and just realised that I was driving with the busted recirc ON for some time now...
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Glad you found that thread helpful, i got mine from a breakers nearly new, A Good tip now is when turning the hot/cold dial 'never' go all the way right or left, stop just short & this problem should not reoccur, There's a little natural settling point just near the end on both hot & cold that's the area to stop at.
  1. Windows Problem
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2011, 19:48
  2. Think i have found my problem, HELP!
    By corderz in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 14:39
  3. Smoking Gun... sorry, diesel problem found
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2010, 18:25
  4. Found out what the problem was.....
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 9th April 2009, 16:32
  5. misted windows
    By pyro_maniac in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2008, 14:21
