Results 1 to 10 of 15
Thread: Bulb Warning
    Regular Member rider's Avatar
    Jan 2006
    YORKSHIRE
    Default Bulb Warning
    My 2.2 LS (2002) has startred showing the bulb failure light but when i checked all of the bulbs were fine. The passenger side rear fog is not lighting up so i changed the bulb anyway but problem still there. Any ideas?
    Nov 2005
    littleborough
    Default bulb warning light
    best to check with both lamp holders out as the warning light is very accurate and a bulb will have gone. dont forget the near side fog bulb is a dummy as there is only 1 fog light.
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    dont forget full beam as well, try ALL and every light, even reverse lights too
    Feb 2006
    Dorset
    Mine tells me what bulb has gone on what corner of the car , although they havent blown , just pulled one out to try it !
    Jan 2006
    YORKSHIRE
    Unhappy
    Already checked every bulb and they are all fine, as for the one foglight I am pretty sure both worked before, I wonder if previous owner bodged the wiring?
    Will investigate further later. Thanks guys.
    Jan 2006
    milton keynes
    i had this problem a few months ago. it was intermittent. the warning light used to come on when it fancied. it turned out to be a dodgy conncetion in the sidelights in the front. i just took the sidelight out and put it back in and it never happened again....
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Interior lights?
    I took a car on a test drive from a dealer and the bulb light was on. I asked what it was and was told it covered the interior/boot, and Number plate too.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    My Veccy has been into main stealers today for the same fault (only a month old). Started off intermittant and they couldnt find it. Over the weekend it became 'Brakelight' all the time on display along with the failure light. I noticed 2 of the 16 leds in the boot brake light were not working, they have ordered me a new one today
    Just a wobbly xenon light to cure now (they want the foreman to take the car home 1 night so he can drive it in the dark - i'm not to sure may just wait till clocks go back!)
    Regular Member 111's Avatar
    Stockton-on-Tees
    Quote Originally Posted by ashdog
    Dito, Really got on my wick.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Must be common, because I had the same, front sidelights. Drove me nuts for ages.
  1. bulb warning
    By dodus in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd May 2012, 17:08
  2. bulb failure warning
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 11:03
  3. Warning Bulb gone ?
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 01:04
  4. bulb warning message help ??????
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2009, 22:07
  5. bulb warning lmp
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 13:30
