Thread: hid kit
    Aug 2010
    herts
    Question hid kit
    went to fit mine to my preface but cant get the bulb clip on am my missing something like these,
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Aug 2010
    herts
    also would these flatten the battery being left on for a couple of Min's as when i go to start it it just makes a loud click/bang thanks.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I found the ones that came with my kit didn't fit, so I just used the original ones and 'stress broke' them at their thinnest points to allow the lamp cable through. Works perfectly.
    Unless this 'click/bang' is more like the puff of a match lighting in silence as you switch them on, I'd be checking for dodgy connections/sparking, etc.
    If all if connected properly, having the lights on for a few mins won't generally hurt.... just don't leave them on while you go for a cuppa and a warm up.
    Aug 2010
    herts
    OK thanks, there no noise when switching them its the car that wont start now but started before i put them on
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'd disconnect them at the part where the car loom meets the HID kit, then check all your fuses - you might have shorted something when fitting the kit. Get the car running, then worry about the HIDs - you can always revert to standard lighting if you need to use the car.
    Regular Member parttimer1's Avatar
    Dec 2010
    edinburgh
    Should the kits come with these if you order a vehicle specific set? I'm looking to order over coming days so don't want too much carry on fitting.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by parttimer1 View Post
    Both sets I got came with 'modified' lamp retainers.
    The modification being that they have a cut to pass over the lamp cable.
    Whereas my original lamp retainers where quite angular where they 'bayonet fit' into the rear of the lamp housing, the supplied ones were far more rounded and I found them a total pig to fit - hence modifying my original retainers.
    Aug 2010
    herts
    got it all sorted now with a new battery as the hids killed mine what was left of it,now whats the best side lights and fog lights also high beam to put with the 6000k 55w kit any links please. thanks.
