Results 1 to 10 of 14
Thread: Is there any way of getting a Windows 95 game to work on Vista?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default Is there any way of getting a Windows 95 game to work on Vista?
    I don't use my Laptop for gaming but the only game in the past that I did was Command and Conquer Red Alert. I've just won a copy on the bay but you guessed it...it wont play on Vista or my old Windows XP. Is there any way round it?
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Right click on the .exe file and use compatibility mode
    Irmscher Insignia CDTI 130
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    i have no idea if it works, but this video may help for installing it on vista http://www.youtube.com/watch?v=AcABN12RiiA
    edit: looking at comments it might not work on vista 64-bit version though....
    Edinburgh
    rebuild your machine to dual boot Win95
    preston
    you can even get old dos games to work by using DOSBOX....
    its easy to install and run
    but yes for Win95 try compatibility first
    some games still won't work despite this
    the other option is to create dual boot system with WIN95 and Vista on it
    fun fun fun
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Big Knox View Post
    I was told dual boots are a very bad idea, supposed to be able to set XP to run as a lower spec, I had some old WP files done in 98SE I wanted to access in XP. The compatibility thing may be the way, I forgot how to do it.
    preston
    dual boot isn't bad,
    i've done this on several machines
    you just need to partition your drive correctly
    the best way to do this once partitioned is to install the older software first to one partition then the newer to the second partition
    if you're feeling brave you can do three OS
    I always partition my drives in any case
    1 for OS, 1 for data , and a hidden one where i keep a slipstreamed version of the OS to reinstall as and when
    thus if 1 partition fails , its easy to get to the other
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    The only way have managed to run older versions of software is to do a clean install with the older spec Windows install the older software and make sure it is running then upgrade the Windows operating system to latest version. Windows is clever enough to leave the elements of the lower version that are needed for software that is installed.
    It worked for me with AutoCad which ran with 98 but not with Xp by doing what I said above it runs perfect.
    Regular Member nick-v2.2's Avatar
    Nottingham
    you could just use vmware player to boot win 95
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Cheers for the input chaps, i'll get right on with the suggestions. If you've played the old C&C Red Alert in PC format you'll know its a brilliant little game
  1. Windows Vista
    By Perry in forum General Chat
    Last Post: 6th December 2008, 04:39
  2. windows vista help needed
    By deano1 in forum The 'Off Topic' room
    Last Post: 20th November 2008, 23:52
  3. windows mail - vista
    By kev bux in forum The 'Off Topic' room
    Last Post: 29th April 2008, 19:24
  4. Windows La Vista Baby!!!
    By thegoldenbullet in forum General Chat
    Last Post: 4th April 2007, 21:11
