Thread: Exhaust flexi size.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default Exhaust flexi size.
    Sorry mods if i've put this in the wrong section but wasn't sure where to put it.
    Got the car booked in at the beginning of Jan at Vauxhall for it's free MOT but when i had it serviced there last month they advised the flexi had come apart.
    I knew this but as i see it it's just the ends of the outer mesh that has come apart.
    Now i'm thinking i'd better get it replaced just in case they decide to fail it even though i think its not blowing.
    Does anyone know the sizes of one for a 2004 GSi and roughly does about £120 sound about right to replace it. I would go back to MIJ to get it done but i think its a bit too far to go just to replace a flexi.
    Glasgow
    The going rate is around £60 supplied and fitted, double that is just a bit much.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    If its just the mesh cut it off, it wont fail on that. Mines been cut off for the last 2 years and passes fine. If your worried about leaks then get it up on ramps, and have a look for any soot marks, or start it up and get someone to put there hand over the zorst and listen out for any noise. HTH
    hull
    If you know any welders mate you can buy the flexi bit off ebay(any size).
    You can even get clamp on flexis but i've never tried them.
    A mate put one of the weld on ones on the wifes hyundai coupe, £30 ebay. Spot on, but i would suggest getting a slightly bigger diameter one as this can be welded over, we went 2mm over but 4-6mm would've made the job much easier
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by byebyeitsagsi View Post
    If only i could find somewhere round here that would do it for that.
    MIJ want £95, Top Gear in St Albans (Powerflow dealer) wanted £120 and i also rang a garage in Bedford that wanted £90 + vat.
    hull
    I was quoted 90-100 quid also by a few places, they would rather just fit off the shelf exhausts i think, much quicker/easier
    Nov 2009
    tredegar
    i had mine done 2 weeks ago, i got a 3.2 gsi, and i bought the flexy from MIJ it was £14.99 plus postage, and it cost me £25 to have it fitted the size you need is 48mm inside diameter, i bought the clamp in flexy
    Jul 2009
    NEWPORT
    So would you get a 100mm,150mm or 200mm 48mm flexi as i have to change mine after christmas
    Weld on
    100mm
    http://cgi.ebay.co.uk/Exhaust-Flexi-...item23065c122b
    150mm
    http://cgi.ebay.co.uk/Exhaust-Flexi-...item23065c0efb
    200mm
  1. Split exhaust flexi
    By Jasond in forum Engine & Drivetrain
    Last Post: 12th January 2012, 23:47
  2. What size flexi pipe section do i need buy for 1.9cdti 150
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2011, 20:11
  3. Exhaust flexi on 1.8 petrol...
    Last Post: 1st April 2011, 11:02
  4. Exhaust flexi pipe
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 18:41
  5. Replies: 0
    Last Post: 4th March 2011, 19:33
https:www.vectra-c.comforumshowthread.php124404-Exhaust-flexi-size
