Results 1 to 3 of 3
Thread: Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    Regular Member DanR's Avatar
    Hampshire
    Vehicle : Insignia 2.0 CDTI Ecoflex
    Trim : Elite Nav
    Engine : A20DTH
    Default Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    Hi All,
    I've been having an issue with intermittent bulb failure warnings on my Vec C for a while now, been loathed to drop the front bumper to look at the nearside indicator but finally bit the bullet today.
    I removed the bulb holder for the indicator to find that there was a hole in one of the contacts, I can only think that it has been arcing due to a poor contact and has eventually burnt through the metal - anyhoo, a quick dab of solder and problem solved (upon removal the driver's side showed evidence of a similar repair).
    Hopefully this may be of use to anyone who finds that they have a similar issue!
    Dan
    SCOTLAND
    Ah thats got me thinking, i have a similar problem with my rear brakelight yet its been working the whole time despite giving me warnings.
    Cheers mate will take a look
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Graeme View Post
    I've had this problem before mate. It turned out the filament in the bulb was loose at one end so sometimes it worked and others it didn't.
  1. Bulb Failure warning
    By Casey in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2012, 16:31
  2. intermittent check rear bulb warning
    By parttimer1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 19:33
  3. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  4. bulb failure warning
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 11:03
