Thread: Noise from drivers side when turning
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Noise from drivers side when turning
    Hi all I fitted my eibach pro kit a few months ago as original springs had snapped. But now Hearing a slight knock or even slight twang when I turn the wheel not all the time just now and then I did grease and clean the strut top bearing and they were in good order so wondered what it could be. I'm goin out now to check the spring and see if I can see anything loose but anyideas would be great cheers
    preston
    maybe a loose bolt somewhere, is the strut nut tight at top?
    otherwise drop links are worth a check
    i'd check all elements of the suspension again from bushes to bearings
    presume wheel nuts are all tight too to right torque?
    also check CV joints if its happening on the turn
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Did you fit sleeves onto the bottom of the spring where it is in contact with the strut cup?
    kings lynn, norfolk
    Checked last night all bolts are tight spring is tight with no cracks or broken pieces and there is no play in any of the arms and links I can see of. Te sleeves are also fitted how ever there was lots of dirt and grit in the spring cup so I power washed it all out to see if that helps I will drive today and have a listen if it's still there what can it be it's only when you turn the wheel and it's not all the time either it sounds like a dull twang and knock
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Second port of call would be the strut top bearings then. Not expensive but a pain to change
    kings lynn, norfolk
    En I changed my springs 5months agony stripped down the bearing cleaned them and greased them up so they were perfect
    Since cleaning my springs out with the power washer it sounds so much better now only there very slightly now but the twang has gone and it's now more of a dull knock
    kings lynn, norfolk
    And the noise is back very time I turn te wheel full lock to lock it's like the spring is twanging I have check springs and all fine it's just started a few weeks ago I have power washed the springs to get all te dirt out but I wonder if it's the salt grit grttig caught under te spring and causing it to jump slightly or it could be worth changing strut top bearings.
    It's only on the drivers side though any more ideas welcome or if you have experienced this before and found out what it was thanks guys
  1. fclunking noise coming from front drivers side wheel
    By dti owner in forum Vectra C / Signum Troubleshooting
    Last Post: 24th February 2013, 17:15
  2. Noise when Turning Ign Key
    By Redviper in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2011, 14:00
  3. PI + B4 fitted - clunking noise from drivers side front
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2010, 20:20
  4. strange noise from rear drivers side
    By chris_20 in forum Engine & Drivetrain
    Last Post: 27th February 2010, 21:47
  5. Wind noise from drivers side doors/ windows.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2008, 20:40
