Thanks Thanks:  1
Likes Likes:  4
Results 1 to 10 of 25
Thread: Outside temp sensor
    Nov 2010
    Default Outside temp sensor
    Hi, I fitted a new sensor because there was no temp display on dash. There is STILL no display.
    Any ideas why?
    Essex
    What sort of display did you have prior to fitting the sensor, was it --oC?
    Regular Member firefox007's Avatar
    Zagreb
    maybe you need to activate with Tech2 or Op-Com.
    Regular Member Robsey's Avatar
    North East Cheshire
    25 Post(s)
    Trim : Energy
    Mileage : 150,000
    I thought all vec c's came with a temp sensor... and the read out on the dispay
    Possibly, just not programmed into either the bcm, and/or the display
    by the way, the temp sensor links up to pins 44 and 47 of the body control module.
    the body control module then tells the display the temperature value.
    As said above,
    make sure that the blue and blue/white wire pair are connected up at the bodyloom plug,
    then these two wires go to the BCM as described.
    What radio and screen do you have? just helps with the query...
    Saying that, I am in east Manchester (Tameside), but work in Withington - pm me your locality / details, and I'll see if I can help
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is the connector between the bumper and the car plugged in? If you have front fogs it would be showing a bulb error but if not then you wouldn't know
    North East Cheshire
    25 Post(s)
    Trim : Energy
    Mileage : 150,000
    I would assume that a car with fogs, would have the temp sensor...
    we are looking possibly at a 2004 full CAN Club or similar entry level vehicle
    therefore no front fogs... just surprised, that there is no temp read out on the main display
    presuming full can as it is a 1.9 CDTi
    If it worked previously, but has only failed recently, then we may be looking at a corroded connector or a plug that is not connected up
    Nov 2010
    My vectra is a club but has been fitted with a new bumber that has fog lights. There is no switch on dash for front fogs. Also, on the bumber there is a female connector with nothing plugged in. There is also a male connector down there that has just one wire. I have no idea what they are for.
    I'm puzzled
    North East Cheshire
    25 Post(s)
    Trim : Energy
    Mileage : 150,000
    The temp sensor loom, is usually part of the fog light loom, but you would need to see if you have wiring to your fog lights.
    Wiring to the temp sensor is 1 x blue and 1 x blue/white wires.
    I have heard of some people wiring the front fogs to come on with the rears, see if the rear fogs come on with the fronts..
    If you wish to cheat, simply run two wires from the temperature sender to the body control module behind the glove box... (pins 44 and 47)
    Tech 2 enabling should not be required...
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by Robsey View Post
    Its actually the other way round, The Foglight loom is part of the Temp Sender loom, All Vec C's come with an external Temp sender unit as standard do they not?
    North East Cheshire
    25 Post(s)
    Trim : Energy
    Mileage : 150,000
    Yeah, but you know what I mean...
    well I thought so, but the OP hasn't answered my query "whether the temperature sensor has ever worked".
    Another question, is what head-unit and display are fitted?
    I don't know of any OEM display that doesn't have the clock function, ambient temperature and current source displayed.
    It has to be a connector somewhere that is not connected up.
  1. outside temp sensor
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2012, 14:09
  2. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  3. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  4. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
vectra c outside temp sensor reading 45 c in winter
vectra c outside temperature sensor
where is temp sensor on bumper on vauxhall signum 55 pictures
vectra outside temperature sensor opcom
insignia outside temp sensor problems
vauxhall vectra c outside temp sensor site:www.vectra-c.com
vectra c outside temperature not working just showing lines
corsa c fog wiring loom temp not working
vectra c outside temperature sensor location
vauxhall insignia external temp sender
vevtra c failing air tempreture sensor symptoms
how do i see outside temp on my vectra c
vectra C outside temperature problem
