Thread: main beams not working?
    Dec 2010
    darlington
    Default main beams not working?
    hello all - my 04 sri estate has a problem ! the main beam lights are not working i have changed the bulbs, checked the fuses and all seems well, however they will not work! the side lights, front fogs etc work as well as high beam but not main beam help please?
    Regular Member Exclusive BV's Avatar
    West Midlands
    must be a relay then
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Or the switch.
    Dec 2010
    darlington
    i will check the switch in the morning - where is the relay???
    West Midlands
    Looks like they are in the fuse box under the bonnet. That's where the headlight fuses are I think.
    Dec 2010
    darlington
    thanks ive looked under the bonnet and all fuses are ok there are 5 relays in there but goodness knows which one is for main beams, how do i test relay??
    West Midlands
    I am not sure without looking in the manual, I found a pic of the fusebox mate. Hopefully somebody can point out the exact relay which controls the main beam
    http://www.flickr.com/photos/54030728@N07/5000753572/
    In the meantime, does the stalk still make the noise when pressed and does the blue light come on the dash?
    East Midlands
    Quote Originally Posted by darlo123 View Post
    According to Haynes it Engine Fusebox,fuse no F8 10 amp.
    Regular Member scottyd's Avatar
    paisley
    its the dipped beam i think he means, as he said high beam is ok, you need to get a test light mate and actualy check the fuses as ivd found not all cars are as per diagram
    13 Post(s)
    Quote Originally Posted by scottyd View Post
    Yes, I think you're right. Main beam to me has always meant the same as high beam.
  1. Are dipped beams rubbish? Or just mine?
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2012, 10:54
  2. Whitley Bay Lighthouse = Rainbow Beams
    By HITFACTORY1403 in forum The 'Off Topic' room
    Last Post: 6th March 2012, 18:49
  3. Quick Replacement Main Beams
    By e55ex_rob in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 17:57
  4. Left indicator and right main beam not working(help)
    By kalim in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2009, 14:10
  5. How high should my dipped headlight beams be?
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:16
https:www.vectra-c.comforumshowthread.php124338-main-beams-not-working
vectra c main beam fusemain beam fuse on vectraopel vectra c low beam not workingvectra c high beams not working
