Thread: Rear Suspension movement?
    Nov 2010
    East Midlands
    Trim : design
    Default Rear Suspension movement?
    Hi, Just been doing some work on the rear brakes of my 04 Vectra 1.9cdti estate, while the wheels were jacked up I thought I would check the bearings by holding the wheel at 12 and 6 o'clock and trying to move it - the top edge of both rear wheels have quite a bit of movement at the top but nothing at the bottom and no play when I hold it at the 3 and 9 o'clock position - thought it may be the bearings but not so sure now - any ideas please, Thanks
    Regular Member Jezzy's Avatar
    S.E
    Check it again with the car on the ground, and look for movement at the top of the tyre, not at 3 o'clock or 9 o'clock. If you find such a movement, then it's highly likely that the bushes in the upper control arm are worn. The upper control arm is the banana shaped bar that hold the top of the hub to the chassis.
    Nov 2010
    East Midlands
    Trim : design
    Thanks Jezzy - can the bushes be replaced or does the whole arm need to be changed?
    Regular Member Dazzy2006's Avatar
    Notts
    Quote Originally Posted by alcutler View Post
    The whole arm needs to be replaced - £30 on ebay
    http://cgi.ebay.co.uk/VECTRA-C-REAR-...item4cf33c96c0
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    and a right PITA to do aswell.
    Dec 2010
    Driffield
    Quote Originally Posted by Morephun View Post
    Hi fella, in what respect are they a pain to fit, do you think.??
    Just had a feel at mine and they have movment, Jim,
    EVERYWHERE
    Just a bit awkward more than anything. No special tools required.
  1. How much movement in tie rod
    By david106 in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2012, 21:01
  2. Odd Knock/Movement..........
    By Lean6 in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2012, 23:37
  3. Rear wheel movement at the top
    By jacko52 in forum Suspension, Wheels & Brakes
    Last Post: 7th January 2012, 19:49
  4. Low front end and movement in suspension when braking
    By Mrmac in forum Suspension, Wheels & Brakes
    Last Post: 3rd November 2011, 17:52
  5. rear wheel movement and noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 5th August 2008, 12:37
