Thread: fault code ? 10-2-5-4 flashes ??
    Dec 2010
    wirral
    Default fault code ? 10-2-5-4 flashes ??
    Hi all, As some of you may know, im a new member trying to get to the bottom of a turbo problem on my 175bhp Z20NET, Deztroyer is currently helping with this .
    Now it may be related but ive done a code reading with brake/accel/ignition and i have found a list of codes from within this site (all very helpful here )
    My problem is deciphering my flashes into a code, im getting :
    10 flashes
    pause
    2 flashes
    pause
    4 flashes
    pause
    then its either 4 or 5 flashes - comes on 5 times but stays constantly lit on 5th ??
    Does this seem right and what code would that give me ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I believe the fault code is either:
    P0254 -Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 -Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    I think 10 flashes = 0 but not 100%.
    From the following:
    http://www.hotrodlane.cc/2009%20GM%2...le%20codes.htm
    Gazza4
    Dec 2010
    wirral
    Cheers gazza ! It was the ten thats thrown me, ill look into it now with my new info
    Phil
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Ed100 View Post
    Phil
    Like I say m8 I think that's what the 10 stands for - hopefully someone will confirm.
    The '10' is explained here:
    http://www.vectra-c.com/forum/showpo...04&postcount=1
    Gazza4
    Dec 2010
    wirral
    well i just wrote a long reply and my laptop stole it somehow !
    Anyway thanks to you guys and this site im getting closer, my codes are :
    * P0244 Turbocharger Wastegate Solenoid A Range/Performance
    * P0245 Turbocharger Wastegate Solenoid A Low
    Which is making sense, though i have just replaced these so will try deztroyers advice next and then back to GM with my solenoids for a swap
    Phil
    Mileage : 000
    Ten flash,s is 0
  1. Fault code
    By rob2.0t in forum Engine & Drivetrain
    Last Post: 21st November 2012, 22:34
  2. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  3. fault code help.
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 12th May 2011, 21:30
  4. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  5. fault code
    By kenny1zero in forum Engine & Drivetrain
    Last Post: 16th August 2008, 20:20
