Thread: Hole in Exhaust back box
    Jul 2010
    rotherham
    Default Hole in Exhaust back box
    Failed the MOT the other day on a couple of things but one thing would be that there was a hole in the back box of the Exhaust, Is this bad for your health as i was reading on the internet something about the exhaust fumes will leak into your car so you should drive with the windows down at all time.
    The main thing i wanted to ask was that i only seem to be getting like 300 miles/360 the best to a full tank of fuel, would this hole affect the MPG and also the all round performance of the car, as i seem to think it is abit sluggish.
    Nov 2009
    Norfolk
    Quote Originally Posted by danny1992 View Post
    Havin a hole in the back box will not put fumes into the car, unless you also have a hole in the bottom of the car near the hole.
    The back back itself has a hole in it normally!
    The hole may affect performance/MPG depending on where it is and how big it is.
    Either way, its has a hole in it. Get it replaced!
    Jul 2010
    rotherham
    I know i need it replaced but just to get it through the MOT i think i may just get it filled in, if it can be filled in. And then when the weather gets better get a whole new exhaust and fit it myself so it will be cheaper.
    Aug 2009
    sheffield
    where is the hole - on the silencer or pipe,or the welding around the pipe going into the silencer ? if its not to big ,i could help. i have a mig welder. pm me ( live in S26 AREA )
    Dec 2010
    wirral
    If you cant get access to a welder as cranny27 has suggested, i believe you can still patch them up for mots providing it is a secure repair, i recently patched one with a piece of thin sheet steel, sandwiched some exhaust paste between that and the box, then secured it with a strip of that steel band and fastening (its like an overgrown jubilee clip). Hope this helps
    Phil
    Jul 2010
    rotherham
    Thanks for the responses, and Yes i am quite close cranny as im in brinsworth, but iv got no idea where the hole is, i havent had time to look now he said there is a hole in the back of your exhasut on on the MOT sheet it says exhaust system ( back box) has excessive corrosion or something like that, but im not aware of where the hole actually is.
    Jul 2010
    rotherham
    And yes Ed i have heard about this , but With the weather this crap i think i would rather pay somebody to do the work then me try it myself as long as they dont go overboard and try and charge something stupid to fix the hole.
  1. exhaust back box
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2012, 16:18
  2. Exhaust Back Box
    By si_hoss in forum Engine & Drivetrain
    Last Post: 20th September 2010, 19:14
  3. Exhaust has hole in flex bit near engine :-(
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 11:44
  4. Replies: 7
    Last Post: 22nd August 2007, 21:16
