Thread: Vec edition100 turbo problem :(
    Dec 2010
    wirral
    Default Vec edition100 turbo problem :(
    Hi all, im new on here annd been having problems with my vectra turbo (Z20NET) going into limp mode, im led to believe its overboosting.
    Can anyone advise as to which pipes to check, the correct routing of the vacuum pipes to check, engine breathers ?
    Thanks in advance !
    Phil
    Regular Member Marcosuk's Avatar
    Fife
    I just replaced much of my boost pipes with silicone pipes from abay.. There are various sizes so check first..
    Its the first cheap way to check...
    Regular Member Jezzy's Avatar
    S.E
    There are two boost valves that sometimes fail, one is next to the turbo, one is at the front of the engine to the left of the throttle body. They cost about £12 each and the part numbers are listed in the Z20NET spec sheet in the Modifying/Tuning section.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    do you hear an hissing sounds more than you are used to? What year is the car, before 06 plates it was Garrett turbo, after that it was a Mitsubishi. The Garrett can have a few issues over time.. I lost power and found the boost pipe tha t goes from the intercooler then under the engine and up to the turbo had a fault, their is a 3 inch piece of hose that joins the pipe to the turbo compressor housing, mine had spilt at the bottom and slipped from under the jobilee clip, just loosened the clip and reseated it all and done.
    Others have had issue with the Charge Air Bypass Valve and replaced them, cost about £25 for the pair, have a read of this thread: http://www.vectra-c.com/forum/showth...light=55354158
    edit: Jezzy is also here, so your in safe hands.. did not mean to post same info was just posting at the same time
    WGAF#5
    replied to the pm as well
    Dec 2010
    wirral
    Default Thanks again
    thanks again all for helping, it seems ive got two threads going on the same fault now ! and a pm's to from deztroyer, ive almost even lost track of my answers, thats how bad it is !
    ok i joke, defo getting closer to a solution i think
    Phil
    Dec 2010
    wirral
    update, adjusted actuator arm out and its looking promising !
  1. Edition100 brakes labour
    By rockhopper in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2011, 07:22
  2. Silver Private Plate Vectra Turbo Pre-Facelift (Poss. Edition100)
    By maurauth in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 7th July 2010, 18:00
  3. Turbo Problem
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 21:01
  4. BBCNEWS24 2.0T Edition100
    By Nidge in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 7th November 2007, 19:05
  5. Clean & Shiny Edition100
    By john_k_sri in forum Quick Photo Album
    Last Post: 11th August 2007, 15:05
Vec Vectra turbo
