I know the snows melting now, but i might butcher a second washer bottle and get one of these...
http://cgi.ebay.co.uk/Toolmaster-12v...2#ht_500wt_715
Working off a switch inside of course![]()
There's a different washer bottle that is much larger, it also has a second pump hole for the headlight washers. You could try and wire it in there so no need to make your own hole.
Sounds like a good plan.
It wont boil like a kettle though, will it ?lol
Quick question. the heated washer jet socket next to the pollen filter, does it just have 2 pins for the live and earth?
Can anyone see any issues with me powering the heater from there so i can use the rear window de-mist switch. Would the fuses need uprating etc.
Might get the heated jets while at it......
BUMP
Did you ever actually fit this and get it working - got another cold snap on the way and this might just help. . .
If its too hot it will crack the screen, can it be set at a low temp? Also if the water freezes would it still be safe to use? U might need to do a few checks using your home freezer
