Results 1 to 10 of 27
Thread: Boost gauge on 1.9CDTI
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Boost gauge on 1.9CDTI
    Fitted my boosty gauge and got a max reading of 22PSI, some what higher than I expected to be honnest.
    Anyone know what a standard 150PS kicks out?
    Going to put the box on now and drive back to work, I don't know whether the boost will be increased or not but I'll sure have fun finding out.
    Regular Member Harry's Avatar
    Uxbridge, London
    probably only the second vec on the site to have a boost gauge fitted. nice one!
    got any pics?
    Duncan and vectra2.0T has a boost gauge fitted I believe.
    22psi?????????
    Regular Member The Doc's Avatar
    'Norf Yorks.
    The common rail engines do boost alot more than the traditional engines. High compression etc.
    [Ex]Admin Duncan's Avatar
    22psi still sounds an awful lot. I'm getting 14psi with my remap. Do the diesels really run that high?
    Where did you tap off for the reading Nutron? I only ask 'cos at the RR day the other day the guys couldn't find a place to tap off on either the 1.9 or 3.0 diesels.
    Regular Member Ian's Avatar
    York
    not actually knowing the exact figures, I would guess that 22PSI is about right - compression in a petrol turbo is say 8:1, wheres a TD its about 18:1. The turbo will need to generate far more boost than a petrol one to cope with the compression.
    Take a look at the size of TD turbo - the 3.0V6 ones can be seen best - they are huge in comparision to a petrol one.
    Regular Member Damian's Avatar
    Market Drayton
    Nutron, is there any chance you could do a How 2 on this, as I fancy fitting one to my 1.9 CDTi as well
    Regular Member Rikkiola's Avatar
    Feb 2006
    Dunstable
    yes how to would be great
    where abouts did you mount the guage?
    any piccies?
    Dec 2005
    St Helens
    Indeed a Diesel engine will like more PSI. A turbo was almost made to go on a Diesel engine, like wise a Super Charger was almost made to go on a Petrol!
    However Boost guage is a bit Escourt Cosworth Like i.e. "Chavvey"
    Quote Originally Posted by Mr_Me
    Well, that'll make me a bit Chavvy then!
    I fitted a boost gauge as I wanted to see what my turbo was doing - after I had lost boost a couple of times (finally traced to a faulty boost pressure sensor). It depends on the sort of gauge and housing as to whether it looks 'chavvy'. I still have only a temporary mount until I find the style that I want - but I definitely ruled out the A pillar style as I personally hate them and think it would look daft in a Signum/Vectra C.
    Here's what I fitted........
    When I find the housing that I like (I've seen them for a Scooby - fit neatly in the corner by the windscreen) I'll tidy it all up.
  1. boost gauge
    By nick2.0t in forum Engine & Drivetrain
    Last Post: 15th December 2009, 17:24
  2. boost gauge 1.9cdti
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2009, 21:03
  3. re boost gauge
    By davidjameswest in forum South Wales (RO - Vacant)
    Last Post: 19th March 2009, 01:00
  4. boost gauge
    By gallag in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 14:13
how to fit vectra cdti boost gauge www.vectra-c.com
