Thread: Help Please, 2.2 DTi Common Fault?
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Mileage : 102000
    Exclamation Help Please, 2.2 DTi Common Fault?
    Hi all,
    During the last few trips in the Vectra I've noticed what could only be described as a vacuum noise coming from the back of the engine (bottom of the windscreen, while sat in the car). I haven't heard it from the outside yet to work out where it is coming from, and still can't open the bonnet until I sort the cable/latch out.
    I have searched the forum as I think there used to be a sticky thread about the 2.2 DTi engine, and a common fault.
    It's getting worse as I drive it, (worse being 'louder'), but it doesnt feel like I am down on power (this could be 'cause I spend most time behind the wheel of a 69PS Caddy Van loaded to its maximum weight). The Vectra is just about to hit 80k miles.
    I am hoping this is just a split pipe somewhere, and should be fairly simple/cheap to fix. Any help much appreciated!
    Many thanks,
    Chris
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds like the wastegate solenoid that sits by drivers top strut,they do make a noise but not all the time
    Irmscher Insignia CDTI 130
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Mileage : 102000
    This is making a serious amount of noise. It sounds like someone is doing the vacuuming, while the turbo is doing its work. Lift off, and it stops the noise completely.
    Edit: Just did a search on "wastegate solenoid" and found some useful threads which seems like identical symptons & solutions! Thanks bigmac for the help!
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
  1. Common Fault
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 00:13
  2. Mirrors fell off - another Common Fault
    By alcutler in forum Bodywork & Interior
    Last Post: 9th February 2012, 14:24
  3. common fault. so I thought
    By mattyj33 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th December 2011, 22:25
  4. It appears its a common fault
    By gary k in forum Engine & Drivetrain
    Last Post: 17th February 2009, 10:34
  5. is this a common fault
    By don paul in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 11:21
