Thread: cd70
    Regular Member hutch's Avatar
    Sep 2010
    TELFORD
    Default cd70
    will a cd70 from a 05 sri fit into my 08 sri, and what type of gps ariel does it need? sen one on ebay with no areiel but everything else.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Quote Originally Posted by hutch View Post
    You can put easily the GPS antenna like this -->
    CristianTM.
    South West
    Transfering from a 05 to a 08 should be no problem. Make sure Screen and HU are a matched pair. It will then just slot in and work. If you can, get the Security Code and ensure that it comes with a map CD!
    The GPS antennas which Cristian posted above are about £6 off ebay. The GPS will sit nicely in the frontspeaker compartment in the center of the windscreen which leaves a nice tidy installation.
    Sep 2010
    TELFORD
    ok thanks guys. think everything included except the ariel. think ill keep a watch on the price
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    The location of the aerial in the speaker box will be hindered, if you have the sun-sensor on top of the dash, for electronic climate control.
    other than that, it should be plug and play
    But yes, do note Aidi's comments regarding audio pass codes etc.
    Sep 2010
    TELFORD
    ok ill ask the seller cheers
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    I have CD70-Navi in my 57 Elite. I have been told on here that I do not need radio code as it is full Can Bus but I have also seen on here that the units have to be divorced from original car and paired to your 08. This has to be done by Tech2
    South West
    As long as the CD70 and display unit are removed as a working pair, they will install straight into your car.
    The time divorcing and pairing becomes a requirement, is if the CD70 unit and a Display unit are not a "married" pair.
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    You will need the original (donor vehicle's security code), if your vehicle is different from the donor vehicle in the following ways...
    with or without ECC (climate control)
    with or without BC (if you wish to change board computer functionality)
    with or without add-on heater
    with or without check control (if you wish to change functionality)
    with or without ice crystal warning...
    I am planning on doing a very comprehensive how 2 for CD70's in the not too distant future... it should then answer most queries
  1. CD70 and Aux in
    Last Post: 8th January 2013, 13:59
  2. Cd70 please help!!! :)
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 10:34
  3. Cd70
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2010, 02:32
  4. cd70
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 20:51
