my 2.0dti vectra brake lights are stuck on cant get them to go off changed the brake switch and still no good
short some where id say
would it b around the back or near the brake switch??
where would the relays b for the brake lights??
have you checked the wiring for the brake pedal switch
another van i drive has a little white plastic push switch down by the brake pedal ...check this to see if broken threy only a few pound to buy if its same easy 2fit
My manual says on page 217 that the brake lights will be on all the time when the ignition is switched on if Fuse 15 (Engine Control Unit) in the fusebox next to the battery under the bonnet has blown.
I don't know what else wouldn't work (if anything) if this fuse has blown, but it seems odd for Vauxhall to have to point out that the brake lights would be stuck on because surely you would notice other major symptoms (such as car wouldn't start or something) if there were any?
