Thread: Engine temperatue
    Jul 2009
    Leicester
    Default Engine temperatue
    My engine temp gauge would not budge so I replaced my thermostat and still it doesn't move, I've done 100 miles on it and still sits there quite happily. What else is there I can check?
    East Midlands
    Quote Originally Posted by dhwigston View Post
    Nowt, its the extreme temps mate,coupled with the natural characteristics of a diesel Vec c.
    Jul 2009
    The Rift, Cardiff
    Did you replace the complete housing including temp sensor and stat or just the stat? If the latter then maybe the temp sensor is at fault.
    Regional Organiser - East Region whiskyno7's Avatar
    norwich
    38 Post(s)
    Vehicle : vauxhall signum
    Trim : 2.0t
    Engine : chipped and remapped
    Year : 03
    Mileage : 100k+
    mine doesn't move when on the move it sit's at 0. but when in taffic or sitting still for a long time it slowly creeps up to the half way marker had the car two years now the cooling fan kick's in about just over the half way
    it say's it all
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    was -17.5 yesterday morning but after 10 minutes of running my temp gauge starts moving and then sits around the 85 mark , stat was changed on Saturday as mine never moved before that
    Regular Member mozzer99's Avatar
    bristol
    With recent discussions there are two areas of concern here;-
    The first is that thermostats (at least on the CDTI 150) do stick open or at least open too quickly.
    The later type is a modified or updated thermostat that opens slower and therefore warms up quicker.
    The second point (that is disputed by some) is that the diesel engine uses so little fuel at idle or very slow speeds that the heater tries to pull more heat out than the engine creates. In these current minus temps you can be ticking over and with the heater on full see the temp gauge dropping down to the min mark.
    It is not right IMHO that you can be running at over 20 mph for any length of time and the gauge not rise - what ever you are doing with the heater.
    If you are travelling at motorway speeds (even this time of year) and the gauge doesn't move to 85c and stay there - change the thermostat.
    Stevenage
    if you go into the hidden menu using the settings button you'll be able to find out what the temp stick is actually doing before it even registers on the gauge.
    I.e. the temp gauge only kicks in at 70 degrees or higher, yet the hidden menu will tell you digitally.
    From this and what the others are telling you you'll probably be able to make an informed judgement.
    Regards
    Paul
    Central Scotland
    I've said this before, the problem is the cooling rad on Vec C's is far too big and cools far too much in the winter.
    An engine running too cold is just as bad as an engine running too hot.
    For a road car the solution is simple. Cut a piece of cardboard the same height as the coolant rad, and half the width. Slot it between the Air-Con rad and (in front) of the cooling rad. Make sure it can easily be removed.
    Keep a very close eye on your temp gauge. If it gets hot, cut more off the cardboard, too cold add a bigger piece of cardboard etc etc.
    What your doing is restricting the amount of ice cold air cooling the rad/engine, and bringing the engine back to optimum running temps.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. exhaust gas temperatue sensor location
    By new2theroad in forum Engine & Drivetrain
    Last Post: 9th August 2009, 00:01
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
