Results 1 to 10 of 11
Thread: Half-Can Steering Wheel Button Wiring
    Bristol
    Default Half-Can Steering Wheel Button Wiring
    Hey guys,
    I've got a pre-face with the half can buttons on the steering wheel.
    Does this mean the buttons interface directly to the stereo?
    If so do you know which wires they are at the back of the stereo?
    Have got a car button controller to interface the buttons with my upcoming CarPC project and need to know which to connect to.
    Many thanks
    Adam
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    no its controlled via the CIM.
    Bristol
    Hmm OK, so the buttons connect to the CIM, then the CIM to the stereo?
    Or is the CIM then on the CANBUS??
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Cim-midcanbus-screen & stereo
    Bristol
    So to get this to work, I'm going to have to tap into the buttons before the CIM then?
    Jul 2009
    The Rift, Cardiff
    I think both sets of three buttons have three wires; illumination, constant voltage and earth. I'm not 100% but I think each button has a resistor that alters the constant voltage when pressed, the computer then converts the altered current into a command for the device.
    It seems the only old fashioned switches (directly connected to the device it controls) in the vec c are on the interior light.
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    True route is believe it or not...
    Buttons to CIM unit ( different resistence value for each button - provides a different signal voltage to the CIM)
    CIM unit to Instrument cluster - Via Low Speed CAN (Data Packet stream)
    Instrument Cluster to BCM (Body Control Modue) - Via Low Speed CAN (Data Packet stream)
    BCM to Display - Via Mid Speed CAN (Data Packet stream)
    Display to Head unit - Via Mid Speed CAN (Data Packet stream)
    Note also that a theoretical zero ohm switch closure will sound the horn!!
    For wheel control set-ups that are programmed incorrectly, any switch closure will sound the horn.
    Jul 2010
    Warrington / Liverpool
    Is there any amount of fiddling that can get the thumb wheel style controls to work on the old 6 button style wheel?
    I hate those 6 buttons the newer controls looked so much better
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    I know you can, if you change the CIM to a newer one.. dont know if its just a code change on the old...
    Oct 2007
    Shropshire
    For the pc get a steering wheel control interface for a kenwood radio. That will give you one wire that is the steering controls depending on its resistance....
  1. Steering Wheel LED Mod : Half Done
    By Envy in forum Styling
    Last Post: 7th October 2011, 07:28
  2. VXR steering wheel with Half Can controls
    By coldo in forum Bodywork & Interior
    Last Post: 24th September 2011, 21:21
  3. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
  4. Steering wheel controls half can
    By Admishere in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 11:29
