Results 1 to 3 of 3
Thread: Blower on max with keys removed!
    Regular Member Kickdown's Avatar
    Nov 2009
    Durham, UK
    Unhappy Blower on max with keys removed!
    Hi guys
    I realise there a numerous threads regarding similar issues but there doesn't appear to be a recent problem directly the same as what I am experiencing.
    I really need some help please - Vectra C facelift 07 plate with semi-auto climate control (temp controls and auto blower without the screen).
    Very cold a few days ago decided to go to car wash to get rid of salt marks from back of vehicle. Water immediately got into the car via the pollen filter where the drain was not blocked but FROZEN shut.
    Heater blower now operates at max, controls not reposnsive. I have to remove the 40A fuse on side of dash to get it to stop otherwise flat battery within a couple of hours.
    There is no resistor pack to change as all of the motor speeds appear to be controlled by the regulator (part no 13250114) which is attached to the bottom of the heater motor. This was full of water - dried/cleaned with wd40, re-fitted, same issue.
    My question, is the the max speed not controlled by a relay? There are three on the left - reverse side of glovebox fuse rack. I have tried removing all three but the fan still powers away at max until removing the fuse. If it is a stuck relay won't removing it stop the fan and identify the fault? Or do I simply need to change the regulator (£200 from stealers)?
    Thanks.
    PRESTON
    If it was a stuck relay, then yes, removing it would cause the motor to cease, so sounds like it might be the regulator, perhaps the circuit on the board has shorted due to water, although what puzzles me is, there should be no power to the blower motor till the ignition is switched on. Will be watching this thread for other opinions, as i have the semi auto air system in my Design.
    Nov 2009
    Durham, UK
    Thanks Barney, just wondered if the relay could be stuck off and causing the same issue somehow - that pretty much confirms it then - the regulator needs replacing
    The motor appears to have a direct 12V supply to the battery for some reason (according to my multimeter) - as I say only thing in it's path is the 40A fuse.
    Speaking from experience I would say one of the MOFSET transistors have failed due to water short circuit (the salty water won't help either) and the circuit is 'stuck' on.
    Has anyone tried replacing any of the components to save £200?
  1. Have you removed your dpf or not
    By winnie2457 in forum Diesel Engine related
    Last Post: 27th January 2013, 20:55
  2. dpf removed
    By figo1805 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 16:59
  3. removed?
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 11:06
  4. Should i get it removed
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 23:04
