Results 1 to 10 of 11
Thread: burning smell
    Regular Member mace's Avatar
    Jan 2008
    Wiltshire
    Default burning smell
    Hi guys,
    I need to pick the brains of the collective.
    Got a 1.9cdti 16v estate with 25k on the clock. Pretty much trouble free motoring apart from some juddering at around 2000rpm under light throttle 4 months ago - Millers , V-power and a Italian tune-ups which I've tried to co-incide with each dpf recon (currently every 450 miles). This approach seems to have sorted that out (touch wood & all that).
    Last few weeks since the freeze started I've noticed a burning smell outside the car when I get out, it's worse on short journey's. Performance is fine (I guess - can hardly give it any welly on the roads here) economy is poor (30 mpg) but not unexpected considering av speed is down to 16mph as I'm mostly pottering about with the work commute/school run about town.
    I'm just perplexed as to what the burning smell might be, it's definately from the front end,around the bonnet and not exhaust / dpf type burning smell, as a 150 estate owner of 3 years you certainly get to know this particular odour, it's not anything stuck on to a hot surface like a plastic bag either. I could only describe the smell as metallic: not oily or plasticky & this is happening on every journey, so if anyone has any idea what it could be?
    Mac
    preston
    clutch?
    PRESTON
    Is it definately a burning smell? maybe there is seapage of coolant from the radiator, which is turning to vapour and it's that you can smell. Is the water level in the header tank reducing?
    Jan 2008
    Wiltshire
    confused
    Quote Originally Posted by mparks8590 View Post
    clutch?
    good point & thanks for the quick response, but it does it when I'm driving and not just when the wifes had it!
    Seriously though, I'm pretty sensible with the left foot especially when stuck in nose to nose trafic. I tend to leave a gap before moving up so I'm not continually riding it. I'm paranoid about DMF problems so I'm pretty careful, can a clutch 'stick' because it's frozen or would it be wear and tear? Are there any other syptoms? Sorry if it's a stupid question but I've not had a clutch problem in 15 years and a dozen cars.
    Regular Member fingers66's Avatar
    Carpe Diem
    I had a burning smell from my vec a few weeks back, 2 days later the waterpump totally mangled...... but it could be anything.
    Jan 2008
    Wiltshire
    Quote Originally Posted by barney490 View Post
    Well I'd describe it as a burning smell but interesting point you raise as I did have an issue last year when I had the coolant indicator come on and the system was checked over and refilled within warranty period. The reservoir was only slightly down and the guys at the stealers were pretty relaxed, said it was common and just topped it up when they had every opportunity to claim "XXX" was fubarred and replace it - I wouldn't have argued, being under warranty * everything. not had a probelm in the 12 months since and I've no wanring lights but I'll be checking the coolant level in the morning for sure!
    Jan 2008
    Wiltshire
    Quote Originally Posted by fingers66 View Post
    Wow sounds expensive! Que sera sera I spose
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    whats it smell like burning rubber ? could be a belt sliping brakes? could be binding on
    Jan 2008
    Wiltshire
    Quote Originally Posted by markj23 View Post
    nah not rubber smell but I'll check wheels tomorrow after the commute to work, it's a fairly easy drive in, especially in these conditions where most everyone is being careful: mostly engine braking and smooth cornering so if I've got a hot wheel I'll know whats going on - cheers for the idea.
    I love this forum Post a problem and the ideas just roll on in
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    What is the coolant concentration like? Does the temp guage move up? Does the heater get hot?
    Just a thought, but could be slight freezing of the coolant if it's too weak, causing part of the engine to run too hot??
    Beforfe you start it in the morning, pop the bonnet and check the coolant in the header tank for signs of ice / slush.
  1. Burning Smell
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 11:36
  2. burning smell!
    By MARK RC in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 19:13
  3. burning smell
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 19:23
  4. Hmm What's that burning smell?
    By Stevel in forum The 'Off Topic' room
    Last Post: 9th March 2009, 21:22
  5. got my sri!!! burning smell!!
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 21:54
vectra c smell burning
vectra c rubber smell
