Results 1 to 10 of 14
Thread: Oil leak? Please see my pics!
    Gävle, Sweden
    Default Oil leak? Please see my pics!
    Please have a look at my pics, I'm suspecting an oil leak somewhere around the area where the arrow is pointing.
    Would this be a common issue? The engine is a 2,2 direct petrol on a Signum.
    It's hard to get a closer look without removing the "filter-box", but maybe I should do it?
    Hope someone can guide me.
    Also: when should the belt (also seen on the pics) be replaced? Guess waiting for it to snap is a bad idea...
    Bristol
    Vehicle : CDTI 150
    Not familiar with the 2.2 so cant say what the leak is.
    However as the belt has been contaminated it will need replacing once the oil leak has been sorted. Also clean all the pulleys with a degreasent. Main issue will be with slipping and the oil will cause it to break eventually but should be more of an inconvenience than catastrophic as it only drives auxilliary components such as alt, PAS and air con.
    Arrow appears to be pointing to the alternator which is not oil fed.
    Best bet is to remove the air box for a closer look.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    front crank seal leaking
    Gävle, Sweden
    Thanks for the answers sofar. Is it a big operation to replace the front crank seal?
    I have already thought about replacing the belt, and now it's perhaps even more critical, even though the engine wouldn't break down if the belt snaps.
    So: is this a huge job? Is it even possible to replace the seal without deassembling the whole engine...?
    Gävle, Sweden
    *bump*
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    not the end of the world to do but judging by your posts you will get someone to do it would think maybe 2 hours inc fitting new belt and de-greasing area
    Gävle, Sweden
    Don't judge me I'm quite good ín the garage actually, even though I seem to be a total newbie based on the posts..
    Thanks for answers so far.
    Please let me know if this is rather easy or does it require special tools?
    Aug 2010
    Luton
    should be just like changing the belt then just when you have it striped down remove the pully on the end of the crank then pop out the seal clean area up refit new seal they just force fit
    Gävle, Sweden
    ok so this seems pretty straightforward then. the seal should basically be possible to pull out with e.g. a screwdriver or something, and the new one just has to be pushed in? Am I right?
    Gävle, Sweden
    Is there any how to available for this? maybe I should put it together when I start working with this.
  1. Few pics of the BTCC finale 2012 at Brands Hatch... (Large pics)
    By RichM in forum Motorsport / Formula 1 etc. chat
    Last Post: 23rd October 2012, 17:24
  2. Vectra 1.9: Slow oil leak - Pics
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2012, 20:58
  3. Help needed with leak on signum :( (with pics)
    By Shogun in forum Bodywork & Interior
    Last Post: 8th November 2011, 14:26
  4. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  5. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
