Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Cruise Control not working :(
    Regular Member Princess D's Avatar
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Default Cruise Control not working :(
    Cruise Control not working I press the buttons and nothing! I checked the fuses on the passenger side and there all okay any ideas
    13 Post(s)
    Brake/clutch pedal return spring?
    Before the CC works, the brake pedal needs pressing at the start of the journey (not every time you want to use the CC I hasten to add).
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    I tried that no difference
    It says in the book not to use when slippery condition now my display unit has been displaying 'caution slippery surface' all day as its below 3degrees, could it be a safer precaution?
    Chelmsford
    Knackered cruise control on Vec Cs is an unbelievably common problem.
    Usually it's down to a faulty switch on the brake or clutch pedal, a dodgy clutch spring (see if lifting the clutch with your foot allows the cruise to engage) or dirty contacts on the indicator stalk.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Typically there is a grease which forms on the switch mechanism, however I used to get the 'check brake light switch' alot. I had the brake switch recalibrated and the cruise control works fine now.
    Gazza4
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Mine doesnt work first time, I often have to click the switch a few times for it to kick in, Im sure someone said you can clean the switch on the stalk, but if you check ebay you can general pick up a stalk for about £14 or so.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Quote Originally Posted by Princess D View Post
    No, it does that every time you start the engine if it's that cold, or if the temperature drops below 3 degrees C whilst you're driving.
    Cruise control works perfectly fine under such conditions.
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Cheers guys Ill have a look at your suggestions! Any idea how much a clutch/braake switch is?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    It just needs re-calibrated.
    Gazza4
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Oh okay guess I'll take it to a garage for that sad times!
  1. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  2. Cruise Control - working again!!?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 19:30
  3. Cruise control not working
    By tommyk999 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2008, 11:13
  4. Cruise Control not working
    By jonnyc in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2007, 04:53
  5. Cruise control not working
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2006, 21:07
cruise control not working on 2006 vauxhall astra
