Results 1 to 10 of 11
Thread: does egr valve req calibrating
    Aug 2010
    south northamptonshire
    Default does egr valve req calibrating
    hi guys i have just purchased an egr valve from vauxhall and they have turnt round to me and said it needs calibrating on tech2. ive got a vectra 1.9cdti 150bhp. is this aload of rubbish and their just trying to con me or is it true.
    many thanks
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Afaik the ECU does all this you could take lead off battery and when EGR is fitted it should relearn
    Irmscher Insignia CDTI 130
    Jul 2009
    The Rift, Cardiff
    I've not heard that before. Maybe they mean the ecu needs reseting which I think can be done by disconnecting the battery for 30 mins.
    Aug 2010
    nice one cheers guys just trying to pull a fast one dickhead receptionists.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    There are software fixes on the earlier cars for EGR related issues:
    http://www.vectra-c.com/forum/showth...oftware+update
    But I don't think there are any for the new design EGR valves
    Regular Member kamar's Avatar
    bradford
    i didnt do nothing as soon as i put a new one on the car was 100%..
    Glasgow
    There maybe talking about plugging it into reset the fault light or do a software update.
    Oct 2009
    Luton
    There have been a number of part supersessions to the EGR valves, ALL are backwards compatible with any software installed. However you may find that driveability is improved with a software update, I found the throttle a bit more responsive lower in the rev range when I did mine in Oct.
    WGAF#5
    most manufacturers on replacing with new egr valves are completing a Tune/download to the engine management ecu which includes a fuel pump and Pilot learn to prevent repeats of the initial failures
    stockport
    Exclamation
    Quote Originally Posted by kamar View Post
    I have an "04" Vectra and put a new EGR on.It was a straight swap,no problems whatsoever.They are feeding you a load of cobblers to try and make money out of you. FELIXX.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. ERG Valve and Booster Valve
    By st2malo in forum Engine & Drivetrain
    Last Post: 9th August 2009, 17:28
  5. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
https:www.vectra-c.comforumshowthread.php124024-does-egr-valve-req-calibrating
https:www.vectra-c.comforumshowthread.php124024-does-egr-valve-req-calibrating#::text=There have been a number I did mine in Oct.
