Thread: Leaking Refrigerant ?????
    Northants
    Default Leaking Refrigerant ?????
    Hi All
    Got a 2004 DTI, just opened the bonnet to check the fluids and noticed a wet patch in the centre of the front radiator. Rubbed over it with the palm of my hand and the liquid is clear with no colour or smell. Also the wet patch is cold. The car hasn't been run for over 24hours and the coolant level in the header tank looks OK.
    Tracing the tubing from the rad it appears that the front rad carries the aircon refrigerant, so now I'm starting to feel a bit gloomy. I'm assuming the refrigerant is leaking and the wet patch is actually condensation. Any ideas or comments?
    There's no sign of any damage and the wet area is below the level of the front bumper, so not caused by impact?
    So now the biq question, the car's under warranty and has full VSH, what's the likelihood of getting this fixed under warranty?? Or is a radiator one of those 'consumables' or 'wear and tear' parts that ain't covered. Just spent £300 getting a new alternator in my wife's car so can't stand another wallet bashing!
    Mark
    you've got a 3 year warranty mate..so on a 2004 car you will still be covered..
    if the refridgerant is leaking it won't appear as a liquid..it will escape in it's gaseous form..
    if the water is present it could be residual remains of the last time it was run??
    Take it back to the dealer..they can pressure test the system and check for leaks.. unless there is obvious collision damage then you should get it repaired under warranty
    Nicking Ya Dinner.
    Its the coldness defrosting in the warm outside air, unless you are getting no cooling inside, dont worry about it, it's the same principle as misting windows if that helps explain it.
    Preston Area
    I get this after running the a/c for a long time.. there was a previous post about it..
    still pumping out very cold inside though..
  1. leaking oil
    By small in forum Troubleshooting
    Last Post: 5th January 2013, 19:44
  2. Disappearing refrigerant!!!
    By MadOnVaux! in forum Troubleshooting
    Last Post: 24th August 2011, 16:36
  3. Air con seems to be leaking :(
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2011, 20:14
  4. I am leaking
    By KevinG in forum Engine & Drivetrain
    Last Post: 19th February 2011, 21:29
  5. air con rad leaking
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 19:05
