Results 1 to 10 of 20
Thread: Weird ice warning problem
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Default Weird ice warning problem
    Been monitoring this over the past few days during the cold weather
    if the outside temp is between 3 and -4 i get the ice warning saying caution slippy roads and the snowflake sign but if the temp is below -4 it doesnt give the warning just the normal temp display in the corner its -10 this morning and no warning and at -6 the other day no warning
    any ideas ????
    by the way its a 06 Facelift CDTi 150 with Nav and CID
    Edwinstowe
    Trim : VXR-D
    nobody got any ideas
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Not sure buddy mine seems to work it was -5 the other day and warning popped up
    Not sure if there's a setting in variant coding that you can alter.
    Irmscher Insignia CDTI 130
    Edwinstowe
    Trim : VXR-D
    well might not be -4 just never had it at -5 , but it was -14 this morning and no ice warning or the other day it was -7 and still no ice warning but i get the warning at -4
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    I noticed this with mine when it was minus 6.5 the other morning, but no warning?
    Edwinstowe
    Trim : VXR-D
    Quote Originally Posted by PeterVV View Post
    glad its not just me then
    Dunstable
    Temperature hasn't been that low here to see, mine shows the warning down to -3.5c which is as cold as it's registered so far, will have to keep an eye to see if mine does the same
    Edwinstowe
    Trim : VXR-D
    Quote Originally Posted by Ademusic View Post
    lol its -10 here now and was -14 this morning
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Maybe the assumption by Vx is that you won't need a warning below -4,
    because they probably assume that the 4 inch thick layer of ice on the windscreen is a give-away.
    I got the ice crystal at -7 this morning
    However, dependent upon which programmer you use,
    Some code index values show "with ice warning" and "without ice warning"..
    Others show with and without BC and
    others show with and without add-on heater.
    maybe some of these indexes have a value for max and min warning temperatures...
    PRESTON
    If outside temperature drops to 3 °C, the icy road surface warning message appears on the display. No message is displayed if the temperature is less than -5 °C.
  1. Weird things Happening Please Help Me On This One! ABS\Dash Warning Lights
    By Street Hawk in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2012, 12:06
  2. Weird problem
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 19:12
  3. WTF - weird screw driver warning
    By steveked in forum Comedy & Humour
    Last Post: 25th April 2009, 08:12
  4. Weird warning light
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 16:59
  5. weird brake pad warning problem !!
    By veccy22 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2007, 20:14
https:www.vectra-c.comforumshowthread.php124015-Weird-ice-warning-problempage2
vectra c sllipery road turning offopel signum slippery roadopel vectra c ice warning disablecd70 navi disable warningopel signum danger of slippery road surfaceopel signum slippery road turn off notificationget rid of slippery roads message on vauxhall vectra
