Results 1 to 10 of 13
Thread: Powerloss on high speeds (z19dth)
    Sep 2010
    Netherlands
    Question Powerloss on high speeds (z19dth)
    Hello,
    I got a problem, when i drive more then 120 km/u and i want to speed up i feel something like a fading* (up/down) and the car speed up a littlebit.
    When i drive 150+ km/u the maintenance light is coming up and the engine stops for a moment (untill i drive 130 km/u or less) and the light is going off.
    This is only on high speeds or on the 5th or 6th gear.
    Ps. i have a automatic gearbox.
    *fading = what i mean with fading = normaly you feel the car wants to speed up, but i feel a speed up 1 sec and then speed down 1 sec and then speed up .... speed down.. The car speeds up but not fast a normal.
    My question, did someone over here knows the problem?
    Thank you.
    Rob
    Engine : 1.9 CDTi
    As your getting a fault light I would get the codes read.
    preston
    egr
    clean it to within an inch of its life
    then clean it again
    drill it and lubricate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like either the 3rd injector plug is need ing to be replaced or the throttle body may be faulty.
    Gazza4
    preston
    could be either, agree
    egr is easier to sort in short term
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by mparks8590 View Post
    tbh the egr valve typically limits power altogether in the upper rev range rather than 'fluctuations' of power. But then anything is possible.
    Gazza4
    preston
    too true.
    but my egr was cleaned first off
    then blipped as described
    a bit of soot was trapped. a tiny bit was all that was needed
    thats why i clean it to within an inch of its life
    worth injector wiring check too
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    too true.
    I've had that too and it was the throttle body alongside the injector wiring. As I anything is poissible.
    Gazza4
    preston
    best bet is to work through in sequence
    check all hoses
    egr
    boost sensor
    throttle body including soldering
    injector wiring
    manifold replacement
    vacuum pump
    after that get back to us
    Sep 2010
    Netherlands
    Hi,
    Thanks people!
    I blinded the EGR valve (with http://media.photobucket.com/image/e...erapics001.jpg )
    I cleaned the boost sensor (it was dirty)
    I cleaned the connectors of the injectors (and replaced one).
    The manifold was replaced.
    I replaced some vacuum pipes, so maybe the pump.
    I will also check the throttle body including soldering and the vacuum pump.
  1. z19dth high consumption
    By tox in forum Engine & Drivetrain
    Last Post: 21st February 2012, 20:08
  2. Help with High Pressure Pump Z19DTH
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2011, 20:59
  3. white smoke n powerloss
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 21:13
  4. missfire/powerloss sorted
    By craigievectrac in forum Engine & Drivetrain
    Last Post: 11th December 2010, 23:11
  5. what kind of powerloss do swirl valves cause
    By bigjoe8707 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2010, 17:36
