Thread: Knackered alternator and EML
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Knackered alternator and EML
    Alternator went on the car this week and although I had a spare (so not too much hassle!) it made the error light come on (car with spanner).
    I was hoping this would clear after so many clean starts but is still showing when ignition is on.
    Does this go away or is it a trip to someone for an expensive reset?!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Sure the EML light clears automatically after 10 days, or if the battery is disconnected for half an hour or so.
    EVERYWHERE
    40 'no fault' restarts should clear it, apparently.
    Bristol
    Vehicle : CDTI 150
    Is the alternator you fitted specifically for the Vec C??
    There are many out there that are retailed by major manufacturers as suitable and give this fault.
    Basically the Vec C specific one has a line to the ECU.
    Whilst the 'generic' item doesn't.
    It will work perfectly as an alternator but flag the EML as it does not feed the ECU.
    This feature was so that the EML would alert the driver to an issue before the alt failed, however in reality it does not work as many will know; the alt fails without any prior warning.
    Get the code read, cant remember what code this gives but its something to do with the 'L' line
  1. Replies: 2
    Last Post: 29th May 2012, 12:53
  2. Battery or Alternator (or both!) knackered?
    By LJ sxi-nav in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2011, 14:54
  3. Alternator knackered - which one do I need?
    By ghandi in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2009, 21:12
  4. CDTI 150 - potential knackered Alternator?
    Last Post: 14th February 2009, 08:45
vectra alternator eml
