Results 1 to 10 of 25
Thread: Just bought an OBD-II scanner
    Chelmsford
    Default Just bought an OBD-II scanner
    £23 off eBay, I'm well pleased with it.
    I've scanned for and reset fault codes so far, and taken a look at the monitoring options. After a 10 minute drive, everything seemed to check out ok, except for the cat, which still read "not ready".
    Anyone know how long it takes for the cat to be checked out? Does it just have to get really really hot?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Linky?
    Wouldn't mind something to clear codes when they appear.
    Had my manifold done and got it reset for £35 then the alternator went and popped it back on!
    Engine : 1.9 CDTi
    Depends what engine you have and how the car was driven.
    From what I remember it's only ready when the cat is upto 300 Degrees or if you have a DPF upto 600 Degrees.
    When we do a full cycle to heck a car out on our scanner it needs to be driven for at least 7 miles.
    Sep 2009
    Glasgow
    can you post a link to the scanner on ebay.
    Tain - Easter Ross
    Liverpool
    I got one a while back as I have a few errors after my led conversion due to some rogue solder!
    Was great and able to reset! Kept in car with all my goodies haha
    Chelmsford
    You beat me to it RobW! That is indeed the one!
    Was just trying to work out how to make a clicky!
    Liverpool
    Quote Originally Posted by RobW View Post
    thats the one i have too
    Oct 2007
    Ripon
    Very cheap item ...... Is it limited in code reading and clearing or is it a handy tool to have?
    Ever saved anyone some cash?
    Engine : 1.9 CDTi
    If you have a Laptop get Op-Com as you can do LOADS more with it and not much more.
  1. Diagnostics scanner
    By icecube10111 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th December 2011, 21:36
  2. Ecu scanner
    By robengland9 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2011, 19:34
  3. Anyone use a scanner ?
    By rob 2.2dti in forum General Chat
    Last Post: 11th April 2009, 17:53
  4. OBD 11 fault scanner.
    By Hoffmeister in forum Engine & Drivetrain
    Last Post: 24th October 2008, 13:30
