Results 1 to 10 of 15
Thread: Best way to boost radio reception?
    Liverpool
    Default Best way to boost radio reception?
    It has started to crack me up now, my aftermarket unit is crap at picking up radio, sometimes even radio 1 is crackly
    Has anyone got any tips to get a better/clearer signal (and not by getting rid of radio lol)
    Anyone had these issues?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    I find turning the 'regional' and 'local' settings off gives a moderately better signal.
    Always have the 'AF' off - too many black spots up here and spends most of its time scanning only to find Radio 4!
    Liverpool
    i have tried all that, but still no good
    Has anyone used a booster? or could antenna be to blame?
    Engine : 1.9 CDTi
    Is the amp in the ariel being powered by the new stereo ok?
    Liverpool
    I wouldnt know!
    Could the feed be re-routed to for instance the cig lighter? Orrrrrrr something 12v?
    Regular Member paul.sessions's Avatar
    leighton buzzard
    i suffer with this too...
    WGAF#5
    the problem with crackles is usually when the heated rear screen is on ...... its an issue with oversensitivity with the aerial base and its location to the rear screen ..... lots of manufacturers have this issue, if you search on google for heated rear screen radio interference it brings up loads of matches .... some people have fitted an in line supressor and its helped others (like me) realise its a poor design fault and usually listen to a cd while the rear screen deices THEN switch back to the radio
    its weird ...the old Siggy never had the issue ... the new one does so it may only affect the vehicles with integrated SATNAV ....
    hopefully if you turn off your heated rear screen you will find the interference goes away
    Liverpool
    hmmmm its really all the time TBH, i just thought i may be able to boost signal with better aerial, or by running another power line to aerial or even getting a signal booster
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by paul_sri150 View Post
    Have you always had it or is it just since fitting your HIDs? Some of the cheaper kits can give radio interference when switched on
    Liverpool
    Nah it's always been bad since fitted
  1. radio reception
    By fiend61 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2013, 10:28
  2. Radio reception
    By Graeme in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2010, 23:16
  3. radio reception
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2009, 17:57
  4. Radio Reception
    By micks edition 100 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2008, 17:58
  5. Radio reception
    By victor in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2007, 11:39
