Thread: replacement of egr valve
    Aug 2010
    south northamptonshire
    Default replacement of egr valve
    hi guys im going to buy veccy a new egr valve for my 1.9cdti 150bhp tomorrow i cleaned out the inlet mainfold were goes onto the egr valve a few days ago. whats the saftest place to run carb cleaner through before i install my new egr valve. or any other places to clean before installing new egr valve. many thanks
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Most people use 10k boost cleaner stuff!, im sure they must sell it on the bay!, part the air pipe by the dipstick, do not put anything in the air box or before the map air flow sensor
    found the how 2 for you!
    .http://www.vectra-c.com/forum/showthread.php?t=98947
    stockport
    Exclamation
    Quote Originally Posted by bridge_eee View Post
    Usually,when you are going to do the "10k" de-coke,the spray is directed through the intake vent at the front of the grille,(or so I am led to believe),so I presume if you want to use something to clean your inlet manifold that's where you would introduce it. However,I hope you understand that any gunge/crap that is dislodged from the manifold will make its way back through the system,(including your turbo vanes!!),before it is burned and expelled via the exhaust.I don't want to alarm you but I thought it best to make you aware of the process etc. FELIXX.
    Aug 2010
    cheers guys will deff try this many thanks
    Regular Member Marky's Avatar
    Jun 2006
    North West
    I can highly recommend you use Wynns EGR cleaner on the throttle valve and Intake.
    Its worked wonders for my engine.
    Its available on ebay here: http://shop.ebay.co.uk/jam100673/m.html. The guy delivers quick and sends instructions.
    See here: http://www.vectra-c.com/forum/showpo...0&postcount=48
    Full Thread: http://www.vectra-c.com/forum/showthread.php?t=86786
    If you want to use it just take the big hose off the throttle valve and spray straight into it in bursts until the whole can is empty.
  1. Swirl Valve Replacement Cost
    By M65 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 22:18
  2. EGR Valve replacement
    By Ubique in forum Engine & Drivetrain
    Last Post: 22nd February 2009, 10:35
  3. EGR valve replacement - take 2
    Last Post: 14th January 2009, 23:05
  4. Swirl Valve on 1.9 CDTI 150 replacement.
    By Chocki in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2007, 17:54
