Results 1 to 8 of 8
Thread: Throttle body help!
    Jan 2007
    Chelmsford
    Default Throttle body help!
    Just taken off my TB to clean it, it's come up lovely with a load of carb cleaner.
    I've noticed that the butterfly plate doesn't fully close by itself, it's partially open and takes a little pressure to shut it fully. It springs back open when you let go.
    Is this normal?
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It should spring open fine. When you switch the engine off the valve will close over to limit the 'shudder' on switch off.
    As for it not fully closing over, this would be normal if it didn't have an idle bypass but I don't know if that is the case with yours.
    Gazza4
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    dont know about the 1.8 but the cdti with ignition off the flap will be fully open, you can push it closed (spring loaded) fully but its firm.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by DNS View Post
    Is this normal?
    I wondered about doing this at some point, dont suppose you took pics?
    Jan 2007
    Chelmsford
    Nah, sorry.
    There's a how2 with loads of photos though.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Link for it, I cant see it.
    Jan 2007
    Chelmsford
    http://www.vectra-c.com/forum/showthread.php?t=79200
    That's for the 2.2 but the 1.8 is pretty much the same
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
  1. Now i think its the throttle body!! PLEASE HELP!
    By o9roberts in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2010, 16:06
  2. Where is the Throttle body on 2.2 dti?
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 14:29
  3. Oil on throttle body pcb
    By fattony in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 22:07
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. Throttle body
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 20:27
throttle plate.doesnt fully close
