Thread: Quick one.. Running cold
    berkshire
    Default Quick one.. Running cold
    I just wanted to check with the ones in the know.. (03) 1.8 petrol
    I presume from my little knowledge that hopefully its just a thermostat but here we go... The temp gauge will not rise ever, unless sat traffic stationary. last week I did 115 mile journey with no stopping & it never mover onceas per usaual! If I idle stationary for 10 mins it will rise steadily untill what I pressume is the radiator fan cuts in & lowers it to an mid way temp.
    Easy fix, or snuffed???? Thanks Ian
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    If it was thermostat, I'd expect it to stay cold all the time, not rise at a standstill, though it could be sticking. Cheapest option to fix, I'd take it out and check it opens and closes.. I had a Supra with those symptoms once, turned out to be water pump, the impeller had rotted/fallen off the inside.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sure it's the thermostat. If thermo is stuck open (or missing), temp WILL rise when stationary as there is no cool air flow into the radiator to cool it, then when you start moving, it cools again... Happened on my Astra, quick fix. :-)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Trim : ES,Panoramic Roof and Power Mirrors
    Engine : 1.8 iVtec
    Mileage : 67500
    How2 available to do this, £10 for a new stat off ebay, £5 for some instant gasket seal and £15 for 5lt of OAT Antifreeze from a VX dealer. Or stick it in to a dealer and don't expect much change off £150.
    http://www.vectra-c.com/forum/showthread.php?t=122762
    http://cgi.ebay.co.uk/VECTRA-C-1-6-1...ht_3819wt_1124
    http://cgi.ebay.co.uk/GRANVILLE-INST...4#ht_500wt_949
    berkshire
    Thanks for response shall try the stat on pay day... Fingures crossed.
  1. Running Cold
    By dc6839 in forum Bodywork & Interior
    Last Post: 29th November 2010, 18:43
  2. Running too cold
    By crgv6 in forum Engine & Drivetrain
    Last Post: 25th February 2010, 20:18
  3. 1.8 petro/lpg running cold
    By Tecnobaz in forum Vectra C / Signum Troubleshooting
    Last Post: 26th December 2009, 20:31
  4. cold running problem
    By rave5 in forum Engine & Drivetrain
    Last Post: 2nd December 2009, 10:32
  5. Cold running on 1.8 vvt
    By jasone in forum Engine & Drivetrain
    Last Post: 7th December 2008, 15:28
vectra c running cold site:www.vectra-c.com
