Thread: headlights control panel backlight not working :/
    Regular Member Princess D's Avatar
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Cool headlights control panel backlight not working :/
    Hi there, where you put your headlights on , my control bit backlight is not working!
    ALSO
    What does it do when you press the button in?
    Any ideas?
    And if its a change the bulb situation how do I do it as on my Astra MK4 it wasn't the easier job as it was solder in
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Ive check the fuses by the passenger there are all okay :/ - I think the last time they were working was just before I put my sony cd player in!
    preston
    what's not working? headlights? i'm confused a bit
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    oh sorry, no the headlights work fine and so do all the switches,
    Im talking about the backlight of the switches
    - it use to light up like the centre console dash and now it doesn't??
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    if you twist the button with the speedo on it it dims the lights have you had a look at that?
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Yeah I have all of the other lights illuminate - heater/display/steering wheel and speedo clocks, its just the ones where you control your headlights no longer light up
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item3cb1c03071
    this part doesn't light up anymore - it works perfectly though just no light!
    preston
    if switches are working then at guess the small bulb or led ( or whatever is behind there ) has died
    either that or a wire has come loose?
    I'd take the part out and check wiring / connectors first
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Took it apart earlier..after figuring out how to take it out! (In my Astra MK4 you were unable to remove that part easily) and the bulb has gone so I'll just get a new one of those tomorrow from slaters!
    cheers guys
    milton keynes
    OK , I take it you have just bought this light switch , if so there is a difference between pre 2004 and post 2004 switches , they look identical but work differently. I am also presuming the only illumination you have is behind the main switch only.
  1. For Sale: Vectra Light control panel without Front Fog control: Cheap!
    By Envy in forum Parts for sale
    Last Post: 19th April 2012, 00:05
  2. climate control panel not working
    By mikeeaston in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:53
  3. My instrument panel cluster is not working
    By bale541 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2011, 11:38
  4. Headlights control bit backlight not working!
    By Princess D in forum Bodywork & Interior
    Last Post: 9th December 2010, 21:50
opel insignia control panel backlight
