Results 1 to 10 of 11
Thread: crd2 fitting help
    Oct 2010
    hull
    Default crd2 fitting help
    i cant get this to work on my car, after connecting the loom and blanking plug my car wont even start at all, ive followed the instructions provided. what am i doing wrong?
    Regular Member Craig1985's Avatar
    Dec 2007
    harwich essex
    Just be a faulty box? Its just plug and play,Unless you have bent a pin on the fuel rail? My connector was a tight fit and felt like it was catching the pins.
    Regular Member wardy's Avatar
    Chichester
    if you have the loom with blanking plug (i.e. no box connected) then it must be a faulty loom, or one that's not intended for your car. Did you buy new or 2nd hand?
    Oct 2010
    hull
    well as soon as i take this loom off and put everything back it starts first time.
    Oct 2010
    hull
    got it off ebay, guy had it on an astra 1.9 cdti 150
    Chichester
    I had a CRD2 on a 3.0 a few years ago.That had an intermittent fault which turned out to be a poor connection within the loom supplied with the box.
    Chichester
    Quote Originally Posted by chris167 View Post
    Might be worth contacting the original supplier as you may need different loom for the vec (at a cost of course). The one I had was made (or imported, not sure) by DTUK. They are a very friendly helpful bunch.
    Oct 2010
    hull
    the instructions state it is for vectra 1.9 cdti 150 aswell so it has to be the right loom?
    Chichester
    sorry mate, no idea if the vect & astra 1.9 have the same wiering or not. But if you are connecting the loom & putting the blank in rather than the box & it still won't start you either have a faulty loom, broken pin in fitting, or it's the wrong loom for the vec.
    Best of luck.
    Oct 2010
    hull
    someone had the plug on upside down.....................
  1. difference between a DTUK CRD2 (09) & CRD2 Multi-Map®?
    By Beckman in forum Diesel Engine related
    Last Post: 10th December 2010, 22:49
  2. MOT, EGR and CRD2
    By spatch in forum Diesel Engine related
    Last Post: 20th February 2009, 21:04
  3. Which map do i use on my crd2 box
    By PAULMAC77 in forum Diesel Engine related
    Last Post: 10th February 2009, 11:40
  4. Noisier engine since fitting CRD2?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2007, 13:03
