i cant get this to work on my car, after connecting the loom and blanking plug my car wont even start at all, ive followed the instructions provided. what am i doing wrong?
Just be a faulty box? Its just plug and play,Unless you have bent a pin on the fuel rail? My connector was a tight fit and felt like it was catching the pins.
if you have the loom with blanking plug (i.e. no box connected) then it must be a faulty loom, or one that's not intended for your car. Did you buy new or 2nd hand?
well as soon as i take this loom off and put everything back it starts first time.
got it off ebay, guy had it on an astra 1.9 cdti 150
I had a CRD2 on a 3.0 a few years ago.That had an intermittent fault which turned out to be a poor connection within the loom supplied with the box.
the instructions state it is for vectra 1.9 cdti 150 aswell so it has to be the right loom?
sorry mate, no idea if the vect & astra 1.9 have the same wiering or not. But if you are connecting the loom & putting the blank in rather than the box & it still won't start you either have a faulty loom, broken pin in fitting, or it's the wrong loom for the vec.
Best of luck.
someone had the plug on upside down.....................
