Thread: radio in safe mode - no "beep"
    Dec 2010
    Wakefield
    Default radio in safe mode - no "beep"
    After battery went flat in my Vectra c 52 sri ,radio has turned into safe mode.
    No big deal I’ve got instructions, code and I’ve unlocked it before.
    “Ignition on... switch radio off..... press and hold AS and switch radio on... wait for beep…”
    Problem is that it does not beep therefore I cannot make any further steps.
    It only shows SAFE no matter what I do.
    Any ideas?
    thanks
    Regular Member Steve01's Avatar
    Aberdeenshire
    could just be a dodgy connection mate. I have done mine a couple of times and I needed to really press it quite hard to get it to beep.
    Might be something else but worth a try!
    Dec 2010
    Wakefield
    worth a try
    cheers
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    was the car jump started? battery removed charged and refitted? If it was jumped started it may well have locked the radio up.... Would try to disconnect battery for 10secs (or remove radio from cage) and then reconnect and retry
    Dec 2010
    Wakefield
    Quote Originally Posted by Steve01 View Post
    You've just earned a pint,mate!
    Problem resolved
    thanks
    Aberdeenshire
    Quote Originally Posted by dcb View Post
    Problem resolved
    thanks
    No problem mate glad it worked
  1. Radio gone into safe mode???
    By Rennie in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 15:05
  2. engine management light "limp" mode
    By welshoneder in forum Engine & Drivetrain
    Last Post: 28th October 2010, 10:31
  3. vectra-B Car400 Radio in Safe Mode - Unlock with op-com?
    By Innes in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2010, 12:47
  4. car radio in safe mode
    By kayli in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 01:25
  5. Extra screens or "test mode" 2009 veccy (CD70)
    By Old man Jimbo in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2009, 14:03
https:www.vectra-c.comforumshowthread.php123941-radio-in-safe-mode-no-quot-beep-quot
cdr 2005 wont turn offvectra c radio in safe modevectra c display safe and wont beepopel signum safe modecdr 2005 safe 7 no beepvectra c radio bip bip que fazercorsa c can not get out of safe modevauxhall corse 2005 no confirmation beep on radio safevauxhall corsa no beep for radio codevectra c radio showing safe after battery changewhy does vectra c radio loses signal when battery is removedcode for vauxhall corsa radiovauxhall corsa radio safe mode no codevectra c stereo safe modecar radio safe mode not beeping when pressing asvectra c radio safe modecorsa c radio safe 8 whats the defaultcorsa c radio safe mode no confirmation beepvectra c radio safe codevauxhall radio safe mode wont beepradio safe problem vectra cradio reset no beephow to shift corsa from safe mode to radioI cant to exit safe mode when I pess AS. mode corsa c
