Thread: 3.2 GSI with cream on Oil Filler
    Regular Member vectrasimonsri's Avatar
    Dec 2010
    OXFORD
    Default 3.2 GSI with cream on Oil Filler
    Right guys and girls,
    I have just bought a GSi 3.2 2003 and have creamy/emulsified oil forming on the oil filler cap.
    WAIT! I know what your thinking, oil cooler gone, head gaskets gone!
    There is no oil in the expansion tank or creaminess. I have owned more V6's than I dare say except for the Vectra C (this is my first) and never seen this. I have been informed that this can sometimes occour in the 3.2 due to it having plastic rocker covers and the condensation can sometimes cause some emulsified oil to settle under the filler cap. As said before I have never seen this before on any V6 however I have only owned 2.5's and 3.0's using the old white plenums and metal rocker covers. When I bought the car, it had been stood for a month, so when I bought it I did about 50 miles in it to blast the crap out (if this is a good way to describe it).
    Then changed the oil and filter. I have just completed a 400 mile round trip and the problem is still there although improved, except due to the freshness and quality of the oil the creaminess is almost like a layer of milk on the filler cap rather than gone off cream.
    I trust the car and the seller, and I cant see the head gaskets or oil cooler failing as I would have oil showing in the expansion tank and this is not the case. The car drives and runs lovely.
    Can anyone shed any light on this? Is there a breather pipe issue? Are there any other known sources of water ingress? The car has been fitted with an induction cone system and cold air feed, could this be allowing moisture into the throttle body and therefore the rocker covers via the breather? I have never known a filter to cause this though?!
    Seriously I have seen many things, but I am all ears on this one
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Pretty common on the V6 mate, if you have the extension tube on the oil filler still take it off and fit the oil cap straight onto the cam cover.
    The moisture sits in the extension tube
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    very common mate
    Irmscher Insignia CDTI 130
    Dec 2010
    OXFORD
    Oh right, it's as simple as that, at least it's nothing terminal! I must admit I was getting worried. I will do that now and let you know what happens after driving 200 miles tomorrow.
    Cheers and will post pictures soon.
    Dec 2010
    OXFORD
    Many thanks, feel a bit better now!
    Quote Originally Posted by bigmac View Post
    very common mate
    As said its very normal. You can twist and pull the filler tube out and put the cap back in the hole thats left. Cures the problem.
    Dec 2010
    OXFORD
    yes this definitely cured the problem. Many Thanks to all
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    and for my dads 3.2 signum cheers
    Regular Member parttimer1's Avatar
    Dec 2010
    edinburgh
    and mine, cap coming off when I do the HIDS! Had a panic there when checking the fluid levels!
    south australia
    thanks guys. iv had this aswel. i knew it wasnt a problem and it was just slight moisture but knowing that the filler tube can be removed helps heaps
  1. "salad cream" in oil filler cap.....possible causes?
    By uaintsinme..right in forum Engine & Drivetrain
    Last Post: 15th September 2009, 22:19
  2. leather cream?
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 18:17
  3. Ice Cream Van.
    By KC in forum Comedy & Humour
    Last Post: 31st January 2009, 19:27
  4. What to use on cream leather
    By steve1975l in forum Detailing and Car Care Discussion
    Last Post: 26th September 2008, 17:13
vectra c 3.2 gsi expansion tank
vetra c cream
