Results 1 to 10 of 22
Thread: Give up how do u disable a vectra c alarm
    Nov 2010
    st.neots
    Default Give up how do u disable a vectra c alarm
    can anyone help im having problems with the alarm on my vectra c so i just wanna turn it off and leave it off but still be able to lock and unlock my car with the fob does the alarm have a brain that i can switch off thanks adam
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Refer to your hand book, I've never tried it so don't know if its possible to just pull the main fuse, but this may be linked to the immobiliser? so may not be possible, Not many will publicly say how to disarm an alarm system!, it may start a trend!!. If your alarm keeps going off why not try to solve the problem rather than just disarming it.
    Regular Member Exclusive BV's Avatar
    West Midlands
    is it the ultrasonic's that are setting it off?
    if so just press the button on the dash every time you get out of the car.
    Sep 2010
    scotland
    Are ye a mad car feef???? Only a question dont take offence by the the way
    Nov 2010
    st.neots
    lol na im not thief thanks just had anoth with the alarm, ive tried pressing the button inside the car sometimes it works and sometimes it dont ive even unplugged the unit in the roof to but that never worked it now come up on the screen inside the car check safe guard
    Sep 2010
    scotland
    Quote Originally Posted by madvenny83 View Post
    ha dthe safeguard fault in my vectra estate but it was ma dug that done in the sensors in the boot
    Jan 2010
    glasgow
    i think you may be able to disable the untrasonics by op-com /tech 2 have you made sure all the doors and bonnet and boot sensors are working ok? and the boot light is not staying on and there isnt a current drain on the car this may also trigger the alarm system
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Hi mate i had the problem of the alarm going off randomly, it turned out the back up battery in the alarm siren in the boot wasnt holding its charge properly and kept setting its self off, i bought another siren off ebay and it was fine then
    Nov 2010
    st.neots
    cheers i have op com on my laptop so ill have a look using that, i had red up on the back up battery problem so i may look into that one to but it comes up on the screen inside the car check safe guard tho anyone know wot that means my motor is a hatchback
    Regular Member vectraboyy's Avatar
    Safe guard means it has been dissconnected from the siren.
    If you go into the boot, the left hand side.
    Open it up and someone will have pulled out the plug going into the siren. Put that back in and it will dissapear.
    Pulling out the siren will merely stop the Siren activiating, however it re routes through to the horns so is twice as loud when it goes off.
    id it to untill i reconnected it. .
  1. vectra parking sensors disable
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 18:00
  2. Disable alarm?
    By TimK in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2012, 00:33
  3. I'll give the first person 10k for any Vectra!!!
    By lgtuk in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2011, 18:29
  4. vectra 20dti can some help, give advice
    By harry71 in forum General Chat
    Last Post: 1st March 2011, 23:49
  5. Disable Alarm On 05 Vectra.
    By etheridge in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2010, 20:23
https:www.vectra-c.comforumshowthread.php123912-Give-up-how-do-u-disable-a-vectra-c-alarm
vectra c alarm keeps going off
vectra c disable alarm
vectra c alarm fuse
disable vectra c alarm
vauxhall vectra alarm fusevauxhall vectra alarm problemsvectra c alarm siren locationvectra c alarm fuse locationvectra c car alarm keeps going off how to turn off vauxhall vectra alarmVauxhall vectra c alarm fuse locationvectra alarm keeps going off floodedvectra c turn off alarmvauxhall vectra alarm systemvauxhall signum automatic alarm problemvectra c alarm backup battery locationVectra c alarmvectra c alarm resetmy vectra alarm keeps going offopel vectra c alarmvauxhall vectra c alarm keeps going offvectra c fuse for alarmvectra alarm keeps going offvectra c alarm problems
