Results 1 to 2 of 2
Thread: Headlights control bit backlight not working!
    Regular Member Princess D's Avatar
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Default Headlights control bit backlight not working!
    Hi there, where you put your headlights on my control bit backlight is not working!
    Any ideas?
    And if its a change the bulb situation how do I do it as on my Astra MK4 it wasn't the easier job as it was solder in
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    bulb replacment is realy fiddley,not for the faint hearted,
    you press the round switch in and turn it to the off position,whilst keeping the swith in you turn it to the side light on position keeping the switch in turn the switch to the side light on position, press the back plate in will unlock the unit and it can be removed.
    unplug wiring harness,press the bridge retainer down and harness will come out.
    told you it was fiddley it's one of the once done it's easy jobs
    good luck (main thing is take time don't force anything)
  1. c/control not working
    By andy101 in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2011, 01:06
  2. headlights control panel backlight not working :/
    By Princess D in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 20:54
  3. auto headlights, fog lights and levelling system not working
    By jong in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2009, 08:22
  4. Diped headlights not working - Fuse and bulbs okay.. any ideas?
    By Ian2503 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 17:41
  5. Cruise control not working
    By tommyk999 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2008, 11:13
